OBD II Question
Old May 15, 2006 | 09:05 AM
supercrew8131's Avatar
supercrew8131
OBD II Question
Can any one tell me if there is a way to read the trouble codes from turning the ignition on/off. I installed the Fram Air Boost system that I won online and now I have an emissions light showing on the dash.
Old May 15, 2006 | 10:11 AM
ledbetter's Avatar
ledbetter
Do you mean checking the codes without using a code scanner/reader? I haven't tried this, but suppsoedly you can access the codes through the computer's diagnostic. See here: https://www.ford-trucks.com/forums/s...d.php?t=475165.
Old May 15, 2006 | 10:14 PM
xtrm1stang's Avatar
xtrm1stang
That is only fot instrument cluster codes, and other info. I'm not aware of any other way to read pcm codes other than a scanner.
Old May 15, 2006 | 11:08 PM
DiscountPowerPrt's Avatar
DiscountPowerPrt
If you take the truck to Autozone or Advanced auto they should be kind enough to read the codes for you.
HiSPL
Testing.....
Aug 19, 2009 05:52 PM
russellkr
Nov 2, 2002 11:18 AM
dale i
Sep 22, 2002 09:37 AM
rogwelch
Feb 12, 2000 11:29 PM
Jan 28, 2000 06:08 PM
