Check Engine Light- constant on
Old Aug 8, 2016 | 03:51 PM
  #76
Pikachu's Avatar
Pikachu
No, all CA emissions with a relay have a shunt. That's how the PCM monitors current draw on each bank. A module monitors each glow plug individually and will set a glow plug specific code if one fails.
Old Aug 8, 2016 | 04:57 PM
  #77
Gidg's Avatar
Gidg
Sorry, I mistyped Module for Monitor.
Old Aug 8, 2016 | 05:02 PM
  #78
Gidg's Avatar
Gidg
Ca emissions? What does that mean? Looks like my Ex was manufactured in Louisville, Kentucky.
Old Aug 8, 2016 | 06:00 PM
  #79
Pikachu's Avatar
Pikachu
CA = California, as opposed to 49 state or Federal.
Old Aug 8, 2016 | 06:32 PM
  #80
Gidg's Avatar
Gidg
I get that Ca means California but are you saying my Ex is a California Excursion? Did Ford make California specific Excursions? I am confused. Because when I came here in 2012 it was the first time this truck had been in California.
Old Aug 8, 2016 | 06:42 PM
  #81
carguy3j's Avatar
carguy3j
I get that Ca means California but are you saying my Ex is a California Excursion? Did Ford make California specific Excursions? I am confused. Because when I came here it was the first time this truck had been in California.
The SuperDuty 7.3L TRUCKS (F-series) came in both Fed and CA emissions versions, depending on where it was sold originally. The EXCURSION was only offered as a CA emissions compliant model, regardless of original sale location.
I would imagine this was due to a much lower sales volume of the Excursion vs the F-series, as it was not economically feasibly to offer the 2 versions. On the other hand, the F-series was sold in huge numbers, including many commercial / heavy duty applications that would have been emissions exempt anyway.
Also, a number of other states have required CA emissions equipment for years. (NY, NJ, MA for instance). Unfortunately this is a symptom of the CA ultra-liberal, tree-hugging, wussy disease spreading and infecting the rest of the country. CA is such a huge market, that manufacturers bow to its rules/regulations, and then stick the rest of us with them for production cost and commonality reasons. Its kind the same way TX and its backwards religious based educational standards end up dumbing down textbooks for the whole country and filling them with religious half-truths and fantasy, in favor of actual scientific fact.
Old Aug 8, 2016 | 08:00 PM
  #82
Stewart_H's Avatar
Stewart_H
That isn't a glow plug module fault; the vehicle doesn't have one, and the PCM isn't looking for one.
Why do you say his PCM isn't looking for one?
If a previous owner has replaced the GPCM that came on all 7.3L PSD Excursions without changing the PCM, then why wouldn't his PCM be looking for a module instead of a relay?
There are Ford wiring diagrams that indicate some 1999-2001 Excursions did have a relay rather than a module.
There were no 1999 MY Excursions ever made that were sold to the public.
or possibly a bad shunt or broken monitoring wire. The shunt is the metal strap on the large post, visible in your picture.
I do know (thanks to Fat Diesel and Duck Fan) that California prepped F250/350 series trucks that came with the GPR (before Ford started using the GPCM) does have to have that shunt in order to keep the SES from activating.
Originally Posted by carguy3j
don't you also have a visual inspection to pass as well? IF the tech is on his game, he/she will definitely spot that lack of a GPCM.
Yes, but if you have a regular guy that you have used for years, and he knows his stuff, he won't care.
You also have the issue of the emission stickers under the hood/on the right side valve cover. They probably don't match up.
Oooo, I didn't even think of that! The OP can compare the hood sticker with the valve cover sticker to see if they match.
remove your cat, and try to pass it off as though you Excursion came that way from the factory.
It did.
No 7.3L powered Excursion came with a catalytic converter.
This would be a lot easier to pull off with a truck, since they did actually come that way from the factory. But, no Excursion 7.3L would have been configured that way.
They were all configured that way. Only the gassers and the 6.0's got the catalytic converter.
4.) I looked on the map, and I see you're not exactly a short drive from neighboring states, but it may be worth the trip, to register the truck in another state. It looks like either Las Vegas or Phoenix are both fairly straight highway shots, along with any number smaller "border" towns in either state. Do your homework,and figure out whether Nevada or Arizona has more favorable vehicle registration and inspection laws, for you. Granted there may another cost, in establishing some sort of address in either location. Again, do your research. It may be as simple as getting a p.o. box.
Not in Cali. CHP actually look for people trying to do this. I'm not saying it can't be done and is being done, just saying Cali actively looks for people doing this.
5.) Sell this Excursion and buy a CA compliant ( don't you just hate that word?) vehicle.
All PSD Excursions ever made (including the 6.0's) were all 50 state legal.
6.) Move out of the People's Communist Republic of
Please ease up on the name calling. I use People Republik too, but the state is far from scummy.
Only the F-series trucks had a difference where the 7.3L PSD powered rigs are concerned.
If you remember my previous post from earlier...
Originally Posted by Stewart_H
No such thing as a California model for 7.3L powered Excursions, they are all the same, unlike the F-series truck which does have a California emissions compliant model.
All 7.3L powered Excursions came with a GPCM, which that code is indicating you need to replace.
Stewart
Old Aug 8, 2016 | 08:15 PM
  #83
Gidg's Avatar
Gidg
Wow Stewart, that a bunch 'o stuff. Yes, I remember you said that no Ex was made for California but I thought we all decided that NO Ex can have a GPR??? I think Pikachu said there were some 1999 and 2000 models that did and mine is a 2000 so could it be that it always had a GPR? I sent back the GPCM.
Old Aug 8, 2016 | 08:40 PM
  #84
Pikachu's Avatar
Pikachu
Because that code is specific to a relay w/shunt equipped vehicle.
Not all Excursions came with a module. Some had a relay. Also, if the GPCM had been removed and replaced with a relay, there would be a different DTC for failure to communicate with GPCM.
You're correct. I should have specified that as a production date reference.
Old Aug 9, 2016 | 10:49 AM
  #85
Gidg's Avatar
Gidg
So, what you are saying, if I might paraphrase Pikachu, is my Ex is likely factory and I have something bad on the right side of my engine whether it's one or more glow plugs, or any of the other miscellaneous items you mentioned? So is there a straightforward way for us to narrow down the problem on our own? My husband and I are willing to do the work, just don't have the expertise. Also, curious whether you buy into some people's belief that the PCM will throw a code if it senses a non-OEM glow plug?
Old Aug 9, 2016 | 12:19 PM
  #86
Pikachu's Avatar
Pikachu
Bank 2 is the left (driver) side of the engine, and yes, that's the side that's causing the code. You should start by pulling the outer wiring connector off the valve cover gasket and using an ohm meter to check the resistance of the glow plugs. In the socket on the valve cover gasket, there will be 9 pins. The front 2 and rear 2 are for the glow plugs. Check resistance from each of those 4 pins to ground. They will typically be about 2.0 ohms.
No, I don't believe just using non-OEM glow plugs will cause a DTC. I wouldn't use non-OEM glow plugs however, due to the fact that I've seen too many (particularly Autolite) glow plugs swell up and cause problems with removal, sometimes involving removing a cylinder head to take care of it.
Old Aug 19, 2016 | 09:23 PM
  #87
Stewart_H's Avatar
Stewart_H
Sorry Pik, I had forgotten about this thread until I read a similar GPCM thread just a few minutes ago.
I guess Ford might have made a ******* version for direct sales to government entities (anything is possible, I guess), but if they did, it had to be the first set of Excursions that rolled off the line.
The info from Ford has always been all 7.3L powered Excursions were 50 state legal and came with GPCM's.
Yeah, this mistake of mine was caused when my brain did not engage when I read the posted DTC by the OP, and mistakenly associated it with the P0683 no communication code for the GPCM.
Stewart
Old Aug 22, 2016 | 04:50 PM
  #88
Gidg's Avatar
Gidg
Interesting Stewart. But mine does appear to be original and I have no idea about it's life before me. Now we just have to relocate those youtubes on how to troubleshoot the issue. I really hate the idea of having to take it to someone but I may have to.
Old Aug 22, 2016 | 05:04 PM
  #89
Stewart_H's Avatar
Stewart_H
Hmm, I do habitually speed read when I scan threads and posts, but I thought Pik had you squared away on how to solve your problem, no?
Stewart
Old Aug 22, 2016 | 05:09 PM
  #90
Gidg's Avatar
Gidg
Yes sort of:
