Georgia Chapter Join Chapter, Leader: OPEN SPONSORED BY:
June Chat Thread
Old Jun 24, 2016 | 03:42 AM
  #136
hturner12's Avatar
hturner12
Originally Posted by ChiefM
It was for Yancey Bros, the test next week is for them too. Went to my 2 VA appointments and that should be the last of it to finish my packet. I wonder how long until I get a final percentage rating. Sleep test is next wednesday so I may have something else to add to it. Slow traffic on the way back north but at least it wasn't stop and go.
I have a feeling you got the job at Yancey. The don't go to the expense of testing for everyone
Old Jun 24, 2016 | 06:17 AM
  #137
ChiefM's Avatar
ChiefM
No official offer yet but I am pretty confident I have a position with them. It's going to be a huge relief when I am locked in. Looks like my 401K is going to take a huge hit today. Throwing some water on the front yard grass because it is starting to get a little crunchy from all the heat and no rain.
Old Jun 24, 2016 | 07:46 AM
  #138
hturner12's Avatar
hturner12
Everything is going to take a hit today for something that may or may not happen. Yes the bits voted to leave the EU but it not that easy.
Old Jun 24, 2016 | 12:09 PM
  #139
ChiefM's Avatar
ChiefM
Got the old fuel pump with no problems, the push rod fell down and I could not push it back up against the crank so I had to pull the mounting plate, I got it half back in but had to take a break from the heat and sun. My shirt is soaked with sweat.
Old Jun 24, 2016 | 12:12 PM
  #140
hturner12's Avatar
hturner12
I chose to say the inside today
Old Jun 24, 2016 | 01:14 PM
  #141
ChiefM's Avatar
ChiefM
The new fuel pump is in. The last time I changed the oil I added 5 qts of oil, I just got done sucking out 9 qts of an oil and fuel mixture. Still have to change the oil filter and then I will be ready to fill and check her out.
Staying inside today is smart but all my chores are outside. plus it helps with keeping the stomach flat..
Old Jun 24, 2016 | 01:23 PM
  #142
hturner12's Avatar
hturner12
Already cut the grass this week. That the only thing I Had To do.
Old Jun 24, 2016 | 02:28 PM
  #143
ChiefM's Avatar
ChiefM
Go Stephen, Go Stephen !!!!
Opened all the flaps on the carb and the intake was bone dry so it's not dripping fuel into the engine. Changed the oil and filter again after installing the new fuel pump. I then ran her on the muffs for about 30 minutes, checked the timing and adjusted the carb just a hair. She keeps a constant oil pressure of 45 psi at idle, about 60 psi running and she never cuts out.
Before she would run about 5 minutes really good and then would start to run really bad, choke and cough and want to cut off. Shut her off and she was very hard to get to restart SOOOOOOOOOO I think I have it fixed!!!!! May attempt another try on the water tomorrow.
Old Jun 24, 2016 | 02:31 PM
  #144
hturner12's Avatar
hturner12
You rock but if it is hard to start are you sure it's fixed
Old Jun 24, 2016 | 05:00 PM
  #145
Big_Texxan's Avatar
Big_Texxan
looks like yall be having fun.
I picked up the welding job part time, commission based instead of friday and weekend deal. More money in the pocket.
Made the decision, Im going home..
Early next year is probably the latest when I will be out there.
Old Jun 24, 2016 | 05:04 PM
  #146
hturner12's Avatar
hturner12
Your lady going with you
Old Jun 24, 2016 | 05:06 PM
  #147
Big_Texxan's Avatar
Big_Texxan
She will be done with school December. Depending on events, she might not, or she might be here and then make the move out.
Old Jun 24, 2016 | 05:11 PM
  #148
hturner12's Avatar
hturner12
Get her out for a visit and she stay
Old Jun 24, 2016 | 05:13 PM
  #149
Big_Texxan's Avatar
Big_Texxan
oh yeah. We talked about a visit. So we will see what happens later this year. Right now I am focused on working to gain as much capitol as I can and get both trucks ready for that trip out there
Old Jun 24, 2016 | 05:16 PM
  #150
hturner12's Avatar
hturner12
Since you are shipping 2 looking to getting a container and put them on the in one container.
