Another compression question
Old May 1, 2016 | 10:59 PM
SeaCarr's Avatar
SeaCarr
This will be odd but I want to run a compression test. I did not think of this until I had the truck torn down to the frame. Engine is still in with the starter.
What could I use to connect a battery to the starter to crank the engine?
Old May 1, 2016 | 11:14 PM
twigsV10's Avatar
twigsV10
A good set of heavy duty jumper cables on good connections will work, don't use cheap lightweight cables or anything less than shiny connections.
Old May 2, 2016 | 10:54 AM
hiball3985's Avatar
hiball3985
You can get a remote starter switch at any auto parts store, not expensive..
Old May 2, 2016 | 11:28 AM
SeaCarr's Avatar
SeaCarr
How would the connections be made with jumper cables? There is no solenoid between the battery and starter. Bat positive to starter, bat neg to ground?
Old May 2, 2016 | 02:56 PM
Martin Torres's Avatar
Martin Torres
Negative batt to ground. Positive batt to post on starter that normally runs to solenoid.
Old May 5, 2016 | 05:30 PM
Textile302's Avatar
Textile302
Correct me if I am wrong, but get get good readings don't you want the engine to be warm?
Old May 5, 2016 | 09:15 PM
hiball3985's Avatar
hiball3985
Yes, that would be the best way if you had a running engine, also WOT...
Old May 7, 2016 | 12:45 AM
Tedster9's Avatar
Tedster9
Good numbers from a cold engine while not accurate would be OK since they would only get better, as the engine warms. Maybe there's some other factors, but believe this to be the case.
Bad or failing numbers measured cold on the other hand wouldn't necessarily mean as much and would have to retest later before condemning the motor. Although a dead cylinder would be useful to know no matter what?
gysgtbigdaddy
25
Jan 12, 2013 02:45 PM
WMNY
Modular V10 (6.8l)
Jul 11, 2011 02:55 PM
zenmaster
Electrical Systems/Wiring
May 24, 2009 04:33 PM
willba
Garage & Workshop
Oct 9, 2006 01:06 AM
51PanelMan
29
Oct 20, 2005 09:42 PM
