This will be odd but I want to run a compression test. I did not think of this until I had the truck torn down to the frame. Engine is still in with the starter.
What could I use to connect a battery to the starter to crank the engine?
How would the connections be made with jumper cables? There is no solenoid between the battery and starter. Bat positive to starter, bat neg to ground?
Good numbers from a cold engine while not accurate would be OK since they would only get better, as the engine warms. Maybe there's some other factors, but believe this to be the case.
Bad or failing numbers measured cold on the other hand wouldn't necessarily mean as much and would have to retest later before condemning the motor. Although a dead cylinder would be useful to know no matter what?
