Garage & Workshop Tips & Ideas for the garage or workshop. No Truck Tech Discussion
Starter/Generator Test Bench
Old Sep 11, 2006 | 01:19 PM
willba's Avatar
willba
Does anyone know if there are any plans available to build a test bench for starters and generators, this would be for the older type starters and generators. Thanks
Old Sep 12, 2006 | 02:19 AM
Torque1st's Avatar
Torque1st
Posting Legend
I don't recall seeing that info on here or anywhere else... -Sorry!
Old Sep 12, 2006 | 02:51 AM
Ford_Six's Avatar
Ford_Six
Starters wouldn't be hard, you could use a 4" or 5" vise to hold the starter, a battery to power it, a solenoid and push button to switch the current, and a DC ammeter to check it's draw. Of course, you'd have to know the dividing point amperage.
I usually just take my questionable electrical parts to Schucks or Autobone, if it's bad, I go over to Westbay and get a good replacement.
Old Sep 12, 2006 | 09:38 AM
GLR's Avatar
GLR
Just jumper cables hooked to a starter will work, just do the finall conection on the starter ground to avoid any sparks around the battery. On generators it will run as a motor when you hook up the ground and the A terminal. Ground the F terminal and the speed should drop. Disclaimer: This statement is from knowledge obtained years ago and does not reflect any senior moment at th time of statement. Don't run starter or gen too long at high speed.
Old Oct 7, 2006 | 07:48 PM
Dialtone's Avatar
Dialtone
Do a Google search for "Armature growler".
Hint: used to test armaturers for shorted segments
Old Oct 9, 2006 | 01:06 AM
fefarms's Avatar
fefarms
Speaking of knowledge from years ago...
Cheap (light guage) jumper cables will NOT reliably spin older Ford starters -- the kind with the moveble "shoe" that activates the Bendix. In my college days (30 years ago), I condemned someone's starter as "bad" after trying the jumper cable test. The rebuilt starter he bought didn't spin any better than the "bad" starter. (The starters draw a LOT of current at initial startup, and the voltage drop across 10AWG jumper cables and clamps tends to be so much that the Bendix contacs won't close to engage the main coils of the starter.)
I had to talk my way out of that one. It turned out the real problem was a bad battery ground.
The actual problem was a bad engine ground...
If you want to test a starter with jumper cables, make sure they are heavy duty cables, 6AWG or heavier.
jvmcc
Sep 27, 2016 11:19 AM
DaleAPreuss
Sep 15, 2016 09:05 PM
asmith6
Mar 5, 2016 05:34 AM
green_95
Jan 9, 2016 07:28 PM
pogymepls
General Automotive Discussion
Jul 13, 2015 07:08 PM
