Well the arms will not work for the front they are too short but they will be perfect for the rear. Also got a heim joint for the clutch linkage and ordered the stuff needed to put threads on the rod for the slave. I got other parts coming but don't remember what they are. So it will be a surprise when they arrive.
Cleaned up the rockers. Dirty vs clean. They came out well and everything works fine after removing the rust. There is no putting on the threads either Full assembly. Close up of them clean Mock up of the clutch linkage. There will be a heim joint instead of the ball
Cleaned and painted the injector lines Found a hole in the intake man this shipper sucked. Cleaned up the valve cover too And painted. Also got the clutch bleed. This thing is ready to go back together and parts are ordered will pick them up Friday or Monday most likely.
