Full resto finally
Old Dec 27, 2017 | 09:10 PM
  #436
88beast's Avatar
88beast
No pa those are the pics he sent me of it cause it’s been in the single digits here and it takes too much work to go out in that
Old Dec 28, 2017 | 01:05 PM
  #437
Diesel_Brad's Avatar
Diesel_Brad
2wd diesel. Not exactly the best vehicle for winter driving in the northeast
Old Dec 29, 2017 | 09:10 AM
  #438
wildstang's Avatar
wildstang
VT Chapter Ldr
You bought the truck in Texas? If so, how and who did you use to get it to PA?
Old Feb 5, 2018 | 08:23 PM
  #439
88beast's Avatar
88beast
Ok been a while since an update with the new truck getting work, the cold, and cutting up my hand I have not had much time to keep moving. However I have a template for the new gauge pod base to include switches and will have a buddy make that up for me. Then I ordered joints for the rear suspension and dom tube. I have a bracket being plasma cnc cut this week for mounting the links. I’m thinking 4 link on the rear keeping everything outboard will be easier in the long run. Once the gauge pod is done the dash can go back in and I can finish wiring and plumbing. After that it’s a test start and mount t case and the rest of the body.
Hopefully this weekend ill I’ll get some time to get things moving along.
Old Feb 6, 2018 | 09:57 AM
  #440
'89F2urd's Avatar
'89F2urd
It'll be good to see the thread move, this is a good one.
Old Feb 6, 2018 | 09:58 AM
  #441
88beast's Avatar
88beast
Thanks it needs done by September
Old Feb 10, 2018 | 02:57 PM
  #442
88beast's Avatar
88beast
Wait is this a progress update? I think so.
Got it started on mounting the t case today. Worked out a plan and got the idea I want in my head. Made one mounting bracket 3 more to go.
I’m leaving about 18 inches for the stub shaft. I can’t get any straight answers from driveshaft companies they all seem to want the original or every single measurement to get an idea of it can be done or not so we will see how this works.
The drivers side bracket outside the frame.
Old Feb 10, 2018 | 04:01 PM
  #443
bbf385's Avatar
bbf385
I would use 1/4" plate rather than the tube on the outside of the frame.
Old Feb 10, 2018 | 04:54 PM
  #444
88beast's Avatar
88beast
I’m going to put something in there to keep it from crushing.
Old Feb 11, 2018 | 05:29 PM
  #445
88beast's Avatar
88beast
Got more done on the t case crossmember. My welds were crap due to 7018 rod and tons of humidity but they will hold and I’ll clean them up. I gotta finish welding and paint it then put it in for good.
Also got the ps return routed and ps cooler mounted. I figured out the fitting for the feed for the ps pump too. So progress is being made.
Inside the frame mount on other side
The other cross piece is in place and it’s all held together now but I didn’t get a pic
Old Feb 13, 2018 | 09:17 PM
  #446
88beast's Avatar
88beast
Now things are gonna start moving. Got suspension parts in. My brackets are cut and I can now mock up the axle side of the rear suspension.
The bracket on the stock spring plate. The air bag plate and a spacer tube will tie it all together.
The cut for the stock bracket.
Side view.
Front view. Heim joints are pretty big. 7/8 heim with 7/8 thread. Not pictured is 1.25 Id .25 wall dom tuning for the links.
Old Feb 13, 2018 | 09:19 PM
  #447
88beast's Avatar
88beast
Pics don’t do it justice. The bolts are 3/4 inch shaft grade 8 and the bottom hole to the top hole is 10 inches.
Old Feb 13, 2018 | 10:21 PM
  #448
88beast's Avatar
88beast
Ok go big or go home. Put the bracket in place.
I think I’ll add a piece of plate across the back to box it in some.
Old Feb 14, 2018 | 09:39 PM
  #449
88beast's Avatar
88beast
Picked up a bag of new unused air fittings cheap so plumbing will come soon.
Old Feb 16, 2018 | 08:10 AM
  #450
88beast's Avatar
88beast
Started on the suspension bracket yesterday.
I will I’ll be bracing everything. On it today and finishing up with welding.
