Dash Fascia Peeling
Dash Fascia Peeling
My dash fascia started peeling above the cluster a couple of months ago. The other day I noticed that it has started to peel next to the radio. What can be done to stop it and ultimately how can this be fixed or how can the fascia be refinished since they are no longer available new?
I masked my dash around the radio to protect it while installing an iPod adapter. The masking tape pulled the paint off. There's no doubt that the 2005s dash bezels were painted black over black plastic. (I ordered my Ex new and took delivery the day it arrived)
I pulled mine, removed all the switches, vents, nameplate, etc. I carefully striped the area where the paint came off so that it wouldn't leave a mark under the new paint. There are also paint removers made for plastics that could be tried. It really can't be sanded because the plastic underneath is textured.
I used one of the SEM vinyl dyes and I think it came out great!
I'm assuming that the bezel isn't cracked...just the paint above?
Finally, the SD bezels are different with the air-bag switch. The Ex ones are long disco'd from Ford.
I will add that I was surprised how the plate where the 4x4 switch was installed. Looks like Ford has a number of different plates depending upon the options installed...and the plate just snaps in from the front. (I pulled that out, removed the switches, etc to paint the plate so that it matched the rest of the dash....)
