E4ODs were used from 1990-1996. Any 351 truck/van will be an E4OD, a 302 might be a 4R70W or an E4OD. If it's an F/E 250/350 302, it will be an E4OD. Nearly every 4.9 also came with the E4OD.
So E150's and E-250's are a dime a dozen in my area (not literally). What engines and years happen to have the e4od in them?
Your answer is several posts above, copied here:
There are also E4ODs in the 460 and diesel trucks and vans. They won't work for you.
So I've happened to find a Allison trans that is made for a 300 I6. Have not bought it yet as a buddy said I'd need to change the computer on the engine. But I've thought that the mid-early 90's fords have two different computers, one for the engine and one for the trans. Any thoughts?
No, the EECIV ECU handles both engine EFI and transmission control. If it does not see the E4OD, it's not going to be happy. You could go with a non OD, or manual transmission ECU, but that brings you to how are you going to control that Allison?
On that, Why the swap? The E4OD is pretty strong, although it can be a little frustrating in terms of maintenance. So can the Allison. Ask the GM guys about broken extension housings. Also, I would be a little skeptical about finding an Allison designed to go behind a Ford 6. Possibly something designed for an SAE bellhousing coupled with an industrial bellhousing for the Ford, but this sounds pretty expensive and squeezing this into your pickup chassis will be a nightmare.
