Pre-Mod Diagnostics please?
While doing research on the tunes I want from DP, I kept seeing mention of the T500 HPOP upgrade, and figure I'll "need" that too.
I plan to get both eventually, but it will be two purchases spread out over several months. Initially I was going to get the DP tunes first, but I'm wondering if I would see more benefit from the T500 first. The biggest issue I have with the BD tunes is that they seem to fall flat in the mid and top end, but I've read that is likely due to the HPOP no keeping up with even the stock e99 sticks my truck has. So do I get the T500 first and see if the BD tunes wake up, or do I get the DP tunes first and upgrade to the T500 in a few months?
Eventually, I will upgrade to larger injectors but that's not in the budget any time soon.
Now for me I look at things that will make my truck reliable and last for years to come and improve its towing abilities in the event that I need to tow things, or pull a stuck car out of the ditch or something...but that is just me...
DP blamed my brand new hpop not being able to keep up with my tunes.... I'm not talking big HP tunes either 60 and 80.
If you do the tuning first then you'll have to have your tunes redone to reap the benefits of the T500 later. If you do the T500 first you'll just have to remember to tell your tuner that you have it
I'm with Jamie. Check those up pipes too!
Just an fyi the "horsepower" setting claimed by most is a joke. At the end of the day a stock injector truck will make at best 330ish hp in 100% perfect working order.
IMO set your goal (whats your rigs main purpose, towing, racing, daily, or a bit of each) after you made your truck reliable then you can start thinking in mods, first in the list since you got air and exhaust covered would be in this order.
I dont know if you have a hand shaker or auto so before anything at a minimum an upgraded tc and a 6.0 trans cooler,( thats about the only thing my stock 800k tranny has with stock internals)
HPO from TE's T500 or other?
Injectors.
Turbo or at least an after market wheel.
Custom Tunning
All of the obove will varry depending on injector size. Good luck
So.... I noticed your poll didn't have any options at all.
but I agree here, your Pole really is lacking in the options...another thought I forgot when I posted before is gauges I know Pyro gauges (minimum is one, but for best results 2 one for each bank of exhaust headers) and I think also Trans temp (can't remember the suggested others) and one other....
Maybe I can add some info I should have added already.
The truck is an e99 so it already has a WW, just the smaller housing and spyder.
Truck has 278K miles and has been meticulously maintained its entire life, and I have an inch thick folder to prove it.
I have some gauges: trans temp, pyro, and boost.
The trans was fully built with a billet TC, tugger kit, modified VB, and it shifts like its trying to escape from under the truck,lol. Came with a lifetime warranty on parts and labor up to 600hp.
The entire drive line has been refreshed in the last year including the suspension, bearings, seals, bushings, u-joints, and both pumpkins getting inspected and resealed.
I'll be pulling the turbo off very soon to replace the pedestal O-rings that just started leaking. I plan on replacing the up pipe donuts while it's all apart (bellowed up pipes aren't in my budget.).
I'll also be pulling both valve covers and replacing the glow plugs,inj harnesses, and GPR.
Other than that the truck runs like a champ.
I have TorquePro with the Powerstroke PIDs loaded. With a little guidance I can do some logging to make sure the engine is healthy. I can say from a butt in the seat feel, the truck runs great...take it fir what it is. Performance hasn't changed at all since I got the truck, other than feeling slower due to the larger tires. I only ran the BD 100hp tune when towing before, but with the larger tires I leave it in that tune just to feel like it can move at a healthy pace.
I'm not looking to build a pulling rig, or drag truck, I want a solid reliable rig that will comfortably pull my 35' camper and race trailer with ease, and be a fun ripper when unloaded. I'd probably get the 60 tow, decel, 80 tow, 100 performance, 120 race, and high idle. Maybe that gives you an idea of how I use the truck.
I figured sine I had the 15* HPOP I was just out running the pump with the mild BD tunes. I've also been told the BD tunes don't do much for fueling anyway and just change the injector timing curve. All I know is I want as much power as I can get from stock e99 injectors and turbo.
In a couple years I'll be back asking about 200cc injectors and a d66 turbo, but until then I want to max out the expensive equipment with the budget mods like tuning and HPOP. What other options should be in my poll?
d66 and bigger injectors would be a birthday/Christmas type deal, so winter acquisitions. Getting new tunes isn't a huge expense so I'd rather max out what I have now.
Get a Hydra chip and run it... If you need a HPOP, work on that down the road. You dont need one with stock injectors, and I would not get the T500 if you did need one.
Hydra is $375 shipped from all the vendors. It comes with a built in no start, built in stock, 15 programmable settings, unlimited free access to all of Power Hungry Performances library of tunes, free... unlimited...
If you want one of the best HPOP's on the market, tested and proven to out flow the T-500... Google MB Diesel... Cheaper then the T-500 as well.
Currently working on a 20* version as well.
Are you telling me I can max out my injectors potential with just a tune and a stock 15* hop with 278k miles on it?
I've read nothing but praise for DP around here, never heard of hydra...
