Yet Another No Start Problem
Old Apr 4, 2016 | 06:08 PM
  #61
Rusty Axlerod's Avatar
Rusty Axlerod
It will buzz test with an injector unplugged, not sure about the harness reaching but it's worth a try.
Old Apr 10, 2016 | 08:09 PM
  #62
Johnny Bravo 45's Avatar
Johnny Bravo 45
OK, Here is what I found. I had a difficult time finding the ohms as when I would search for an ohm reading, it always went to zero or -1. regarless of which pin i used. This was both no. 2 and 4 injector's.
I was able to put number 2 injector wiring harness on to No.4 injector. I then did the buzz test and with the no.2 wiring harness on no.4, no. 4 fired second and I had number 4 wiring harness disconnected which of course, did not buzz. BTW, on stock configuration, number 2 did not buzz at all
From this, I can only assume that my number 2 injector is bad.
Help me with my plan....
From here, I plan to purchase a new OEM (maybe remanufactured) fuel injector for no.2
I also figure I should get the rebuild kit for all 7 injectors and do the nipple cup gaskets too.
Is that too much or should I go deeper and get all new 8 nipple cups too? I don't wanna do this job again and figure replacing the one injector and rebuilding the remaining 7 plus new nipple cup gaskets &/or nipple cups may be the way to go. Heck, if money was no object, I would replace all 8. Consequently, I don't have a money tree
Thank you all very much!
Old Apr 10, 2016 | 08:24 PM
  #63
Johnny Bravo 45
HELL! I reconnected my injectors number 2 and 4 to the correct places and thought, let's try another buzz test. I did and now they all buzz??? One battery is low & it would not start as I had the hood open & radio playing for the past 2 hours Charger is on now and looking to see how it runs?
Any thoughts? I wanna kill this truck kind of
Old Apr 10, 2016 | 09:20 PM
  #64
Johnny Bravo 45
OK, I put everything together and she is running or idling perfect. I suspect a few things. One, possible problem from the PCU and /or FICM to the injector. But BEFORE I go thinking worse case situation.
My truck ran fine before I replaced the ICP sensor..or cleaned & installed a new screen on the ICP. I did remove injector harness. So, maybe a bad connection to inj. no. 2 or a possible short
OR, bad connection to FICM?
OR, possible issue with FICM since battery on drivers side is a bit low. At idle, I've been getting good volts. 13.2-13.8..if memory serves me correctly? I cleared all codes which were p0264 AND p0266.
Any ideas of how to chase possible problems here???
Thanks again everyone!
Old Apr 11, 2016 | 05:49 PM
  #65
CPB1's Avatar
CPB1
At this point I would just keep an eye on it. It's possible you just had a loose connection. If it happens again I would suspect the FICM harness.
Old Apr 11, 2016 | 11:46 PM
  #66
Johnny Bravo 45
I think you are correct! Drove her 40 miles and she ran great! No codes. I plan on changing all filters plus coolant filter and adding a little archoil just for added protection
Old Dec 1, 2016 | 11:19 PM
  #67
FrankNBeans's Avatar
FrankNBeans
Oops, the pics inserted before my post instead of after
Old Dec 2, 2016 | 12:10 AM
  #68
Johnny Bravo 45
Just to follow up, Put a few thousand miles on her with no problems. That loose injector in fact was the problem. Just in case anyone else has the same problem and does a search on this topic
RobMF250
Jul 20, 2018 08:20 AM
MurderMode
Apr 30, 2017 12:06 AM
kissimmee
Oct 16, 2014 10:23 PM
bowbender_1969
Jun 11, 2012 11:00 AM
NYC F-350
Feb 27, 2011 10:25 PM
