No start fixed, questions remain
2006 Lariat with the 6.0
Owned the truck for about 7 months now, every fluid has been changed, always run cetane boost/conditioner. Runs like a raped ape.
Had a no start condition on my truck two days ago. Truck had acted strange twice in the past 3 weeks, thought it was just a fluke. 1 hard cold start, 1 hard hot start.
I read the "no start checklist" but I am severely limited because I do not have my tools with me.
Truck cranks normally but will not fire.
I check oil level, fuel related items and check for codes, blown fuses.
No codes, everything appears normal.
Next thought is ICP sensor.
I check the plug area for oil, see nothing, so I unplug the sensor and immediately try to start the truck.
Truck still cranks normally, just does not fire.
I resign myself to the fact that I have to get it towed to a dealer (NYC does not have many diesel shops).
I call the dealer this morning and they tell me that the first thing they checked was the FICM (checked ok), then they unplugged the ICP, it fired right up. They are doing a few more checks, replacing the ICP and truck will be ready in a little bit.
Was I supposed to wait a few minutes after unplugging the sensor before starting??
They say they monitored the sensor and got some real crazy readings at idle.
Could those readings (given the very sparse info given) possibly point to a slight STC fitting failure, an HPOP problem, or am I just being overly paranoid?
If you have a hpop leak it will show itself after being hot and on a restart, or lack thereof. ICP is possible but not real likely. Check the ficm voltages yourself. Do a search on here for directions. It will take you longer to read the directions than to test the ficm. And no, you dont have to wait a few minutes after unplugging the ICP.
I'm on my way to go get it. I will have to stop somewhere to buy another multimeter (my 3rd). My tools are 300 miles away.
I have read how to check it, hoping to find a meter, no such luck.
Thank You for the reply
Saturday evening, after being parked for three hours, NO START.
Engine cranks quickly, will not fire.
Rechecked the "easy" stuff (fuel pressure, fuel presence, oil presence and flow in housing) and found everything normal. Since the engine spins so fast with a turn of the key, I am going to assume the batteries are ok.
Got out the multimeter I bought and checked the FICM. 49 volts with key on, 48.5 cranking.
Please let me know if I am off track or there COULD be another answer. I welcome any and all comments. Heres what my pea-brain has come up with.
I think that the STC fitting (or other HPOP related issue) is the actual culprit.
When the dealers mechanic checked the ICP, and saw fluctuations, they were the actual readings and not a bad sensor. They swapped out the sensor, probably never verified by rechecking the readings, and called it done. Truck fired, ran, so it must have been fixed.
Heres the weird thing about this, both times I have had problems starting it is when the truck is parked on a hill, hood up, tail down.
Is this just a strange coincidence, or is there some reason for this?
Should I go and let the truck roll downhill and try it on the flat?
I don't see why/how this would matter. Maybe it is hopeful/wishful thinking.
Next time this thing fires (if it will before I have to tow it), it is going on a 300 mile trip to where my tools are. I am going to spend some quality "wrench time" with it.
I have everything together for the CCV mod, egr delete, straight pipe it, and a clean intake manifold standing by. Might as well order the updated turbo drain and the IPR screen kit.
Maybe post count related issue??
I will try the "park on the level" tomorrow. Hope it works so I can get it to where I can work on it.
Thank you very much for your help, matty169
there is some more diag to this if your going to do your own work I can cover it after you confirm a few times that your truck will start when parked nose down.
there is an old thread around on this with some video.... if you feel like hunting the search fucntion.
Thanks for your thoughts so far.
I will report back what happens tomorrow during the day.
Have a great night guys.
