Disaster Thread for 6.0
Now just a waiting game on my coolant flush. I bought restore and restore plus and will arrive tomorrow.
Yes EOT verses ECT no more tha 15 deg spread , if or not already plugged oil cooler when you use chemical flush will plug it, that's mainly right before a new install. I see you for got to hook the fan up so you can still monitor FSS , Fan speed sensor. Are you testing the head spread unloaded on flat road ( no hills) at 65 mph?
http://www.fordparts.com/fileuploads...icationkit.pdf
Better later than never. I posted the link and uploaded the file as 2 PDFs.
Sean
6.0L Tech Folder
Soooo
I was flushing coolant today.bdid the procedure with T-Stat removed. Had RESTORE in it with Water. Driving around town and highway for about 45min. The ECT was at 144 and EOT was 205. Got nervous and stopped. Opened up radiator cap and it started to hiss, sizzle and it puked when it got opened enough. I quickly closed it. It was white foamy stuff.
I took the plastic drain off from radiator and hazy white started to flow, it was steamy hot.
I guess I have an Oil Cooler that needs replacing...?
When I depress pedal on highway to get PSI up to about 28, there would be traces of smoke coming out, not white, but not a dark black smoke either, but that was before all of my nightmare.i think I can manage oil cooler replacement, if necessary, ofcourse, but isn't the white smoke a headgasket issue...??
got me nervous! I heard that if you have an oil cooler clogged, doing the chemical flush will accentuate it, so I was thinking that that was what happened. But definitely have NO white smoke! Anything else I should look for?
DO NOT do a cooler until you do the cooling system test!
ECT/EOT temps are not as critical if the EGR and cooler are deleted! SEE the TECH FOLDER.
I searched cooling system pressure and found nothing..!
I need help though...is this really not oil cooler? I thought I was buying a bullet proofed truck..why are the head studs coming off..?!
My system is currently empty of coolant, since it is just air, I will assume that I can go ahead and skip the vacuum test and go into pumping the system up to 15psi without pushing coolant into the cylinders.
My question at this point is are you guys saying that I may have oil cooler and head gasket issues? I thought the massive delta between ECT and EOT was a sure-fire oil cooler failure.
variety of modifications. not all of them help engine longevity.
one red flag for me was the "tunes". you may notice if you stay
on here a while, there are a few people that come up, over and over.
ed@ficmrepair.com for ficm disorders
matt @ gearhead for good software.
dc power for alternators.
bulletproof diesel for various bits.
ARP studs.
stellite valve seats.
i've used all these guys, and it all works. i don't have cooling
issues, i don't have charging or ficm issues, i don't have lack
of power issues. i'm about +100 hp and +150 ft/lbs over stock.
van's got 80k since rebuild, and works flawlessly. at 175k now.
hopefully, it'll last for the rest of the time i need a van.... i'm
not putting much in the way of milage on it these days... work
has changed, and i got a new work vehicle, that i'm running the
wheels off of.... 2016 CTS-V. seven weeks, 8,500 miles.
so i'm not on here that much any more, as most of my life is spent
on the highway... but for what it's worth, this particular little forum
is the single best source of information on the 6.0 ford that exists
anywhere.
now, that CTS-V, it's not got the godzilla motor, it's got the ATS
twin turbo V-6, which got a tune from a guy in texas, and produces
500 RWHP, and cruises at 85 mph, getting 28 mpg.... so if you get
your badass tune loaded, and go out to humiliate some of the power
sedans, pride goeth before the fall.... top speed i've gotten from this
one so far is 171 mph... but i'm guessing low 180's is where it'll tap out.
not bad for a 4,000 lb car with a itty bitty v-6.....
show with air pressure till it was HOT but showed right away
under vacuum.
When you say all air just how far down is the coolant? You may have
a leaking block drain plug. Look both sides of the block behind the starter
and the driver side just back from the engine mount you will see 2 hex
sockets. They most times are a bright zinc color.
Sean
6.0L Tech Folder
