'55 panel build
Old Feb 11, 2018 | 06:13 PM
  #211
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
Like the look!
Old Feb 11, 2018 | 06:51 PM
  #212
ooraider's Avatar
ooraider
Nice looks good
Old Feb 11, 2018 | 07:22 PM
  #213
sstephanuik's Avatar
sstephanuik
ttpenman, sorry I didn't see your post until today. I never got notified of it by email.
As far as removing the body from the frame I used an engine hoist to raise up the front then built a temporary 2x10 frame that went the length of the cab back. I made some 4x4 posts for legs and attached casters to those then lowered the frame onto wheel dollies and rolled it out. I'm hoping I only have to take it on and off one more time as it does take some time but is well worth it for ease of working on the frame.
As far as the work goes I'm doing all of it by myself. My next door neighbor gives me a hand with heavy stuff or when I need a couple extra hands. I use to work at a body shop part time when I was younger and picked up a lot of things there that help but mostly I've either watched youtube videos, read articles or just learned by doing. Sometimes that works out and sometimes it takes me 10x longer to do something but you hone skills quicker by making mistakes I feel.
I've had the truck like 2 1/2 years or so now so I haven't been working on it like crazy and have gone more overboard on it than I originally planned to but figured might as well make it how I want it the first time.
I started my own business about the same time I got the truck and that has taken off so it really limits my time on it. Lately I've just tried to take one piece at a time instead of jumping around and not getting anything done. The front end now is almost all in primer except for the hood (which I have yet to fully media blast). It is going to be a chore to get straight I think but its only metal.
Any questions you have feel free to ask and I'll answer them the best I can with the knowledge I have.
Old Feb 11, 2018 | 09:06 PM
  #214
ttpenman's Avatar
ttpenman
Thanks
sstephanuik --- Thanks for the info. I've had my Panel for 30+ years. Seems like whenever I have had the time, I don't have any money and then I have some $$ I have no time. It's has been inside for most of that time but outside the last few years. Really scared to see what kind of shape it's in when/if I get to tearing it down. Hope I can salvage it. I know it hasn't been on the rode since the late 60's (long story).
Glad your business is doing well. Mine hasn't and I'm now trying to run out of my home, plus, I'm trying to semi-retire. Hopefully this summer I can spend some time on vehicles. I have an 86 F150 that I'm hopefully be able to learn some things on before I try to tackle the 55. I hope things go well. I also hope to get my garage rearranged enough to get the 55 back inside with enough room to be able to work on it.
You look to be doing good work so keep it up. I'll try to keep watching your posts for inspiration.
Old Feb 12, 2018 | 08:16 PM
  #215
ooraider's Avatar
ooraider
Originally Posted by ooraider
https://www.ford-trucks.com/forums/1...d-rebuild.html I am looking to see if anyone has installed a 53-56 Pickup gas tank in a
Panel truck in the pickup location, I have a custom tube chassis and do not have room under the truck in the panels stock location and have a narrowed
rear and it does not leave much room for a tank between the chassis in the rear.
or if anyone knows if someone has.
Old Feb 12, 2018 | 08:48 PM
  #216
sstephanuik
Don’t know of anyone that has done that. I’m tying to decide what I want to do for a fuel tank still. Stay stock location or fab something in back. Haven’t found anyone that’s done a fuel door location that I really like.
Old Feb 12, 2018 | 09:10 PM
  #217
ooraider's Avatar
ooraider
I feel i can put a fuel door in the panels stock location but guess i might just have to see if the tank will fit.
Old Feb 12, 2018 | 09:17 PM
  #218
sstephanuik
Did the pick up have two locations? I’ve heard some had the tank in the cab? Which seems insane. I’ve never looked at where the underside tank went.
Could you fit a tank between the frame and outer side of the body?
Old Feb 12, 2018 | 09:21 PM
  #219
ooraider's Avatar
ooraider
I had a 53Pick-up years ago and the tank was between the frame and the body, strapped to the running board mounts, I heard that 56 may have been behind the seat
in the cab.
Old Feb 12, 2018 | 09:30 PM
  #220
56panelford's Avatar
56panelford
The 56 pickup did have the tank behind the seat and the filler neck was behind the door handle on the passenger side, however I found out that some pickup had tanks in the same location as the 53-55 driver side mounted to the running board brackets. The panels had the tanks mounted on the inside of the frame rails on the drivers side..
Old Feb 12, 2018 | 09:43 PM
  #221
ooraider's Avatar
ooraider
I really appreciate all you guys help.
Old Mar 1, 2018 | 08:01 PM
  #222
ooraider's Avatar
ooraider
I have not seen any updates lately
Old Mar 4, 2018 | 02:15 PM
  #223
ooraider's Avatar
ooraider
don't know if you have a minute but I am looking for a fairly accurate .measurement of the back door opening at the lowest and side to side and outer most edge of the frame of the door.. thanks hope to hear from .
Old Mar 5, 2018 | 07:57 PM
  #224
sstephanuik
Hey there, sorry been really busy lately and haven’t hardly looked at my truck lately. Email me at scottstephanuik@yhoo.com. For some reason this site isn’t emailing me when someone posts on the thread.
Old Mar 7, 2018 | 05:03 PM
  #225
ooraider's Avatar
ooraider
scott i tried that email and it said it was not valid
