'55 panel build
Old Jan 27, 2018 | 05:25 PM
  #196
bjmayberry2's Avatar
bjmayberry2
Veteran: National Guard
You’re gaining on it!
Old Jan 27, 2018 | 06:43 PM
  #197
56panelford's Avatar
56panelford
You did a very nice job on that fender..
Old Jan 27, 2018 | 07:41 PM
  #198
ooraider's Avatar
ooraider
They look great.
Old Jan 29, 2018 | 09:22 PM
  #199
ooraider's Avatar
ooraider
Thanks for the insight on shaving the drip rails, I'm running with it
Old Jan 29, 2018 | 09:27 PM
  #200
ooraider's Avatar
ooraider
https://www.ford-trucks.com/forums/1...l#post17761857
"ooraider"
54 f100 Panel rod/rebuild
Thanks again for your insight this is my Thread.
Old Jan 31, 2018 | 05:27 PM
  #201
sstephanuik's Avatar
sstephanuik
Looks great.
Old Jan 31, 2018 | 07:57 PM
  #202
ooraider's Avatar
ooraider
I used Direct Sheet metal.,"http://www.directsheetmetal.com/" , I had purchased the 4' setback {Big Block} firewall many years ago from them and When I called them they set me up with the proper toe kicks,
they now sell the complete floor and toe kick setup and firewall.
I'm very happy i went this route seeing i have a big block 460 for the truck and all my measurements was cutting it to close with factory firewall.
Old Jan 31, 2018 | 08:02 PM
  #203
ooraider's Avatar
ooraider
Thank You.
Old Feb 2, 2018 | 08:51 PM
  #204
ooraider's Avatar
ooraider
Did you have to leave some metal above the back doors when you shaved the drip rails.
Old Feb 3, 2018 | 02:18 PM
  #205
56panelford
Remove small sections at a time and weld over the cuts..
Old Feb 4, 2018 | 10:53 AM
  #206
ooraider's Avatar
ooraider
Do you have a picture of how you finished your shaved Rear drip rails. Thanks
Old Feb 4, 2018 | 02:23 PM
  #207
56panelford
I only shaved the gutters from the rear door to eliminate interference when the door was lifted. These are the only pictures I can find at the moment.
How it looks afterwards..
Old Feb 4, 2018 | 04:56 PM
  #208
ooraider's Avatar
ooraider
Thanks i am worried there is not much for a good seal
Old Feb 6, 2018 | 02:03 PM
  #209
ttpenman's Avatar
ttpenman
Just finished reading your build posts. Nice job and great information on your build.
I have a 55 Panel, same color as yours, in about the same shape although I haven't begun to tear it apart so not sure what I will find. Your posts give me hope but also make me wonder if I will ever get a chance to really get into it.
Have a ton of questions but I'll start with a couple -- How did you remove the body from the chassis? I know some people have used a forklift since it is so large. Curious how you did it? Also, are you doing most of the work alone or do you have help? Some of the projects look pretty daunting. Just wonder how you manage it.
Keep it up, I look forward to more posts.
Old Feb 11, 2018 | 05:54 PM
  #210
sstephanuik
A little Sunday truck ****. Got the ps fender body worked and in high build primer today. Also cut off the frame horns and mounted the front metal loosely.
