Electrical-drivers side window
Old Sep 19, 2015 | 04:53 PM
dn29626's Avatar
dn29626
I took it apart and used a fingernail file on the contacts, working now. I will report back in a few days on how its working.
Old Sep 21, 2015 | 08:26 AM
brian42's Avatar
brian42
Veteran: Navy
Glad you were able to fix it.
I don't know if you priced any but you dodged a $110 bullet ($80 if you buy 3rd party). Congrats!
Old Sep 21, 2015 | 02:42 PM
dn29626's Avatar
dn29626
Not fixed, disappointed
Relay under the dash clicks each time I press the switch, but the window does not move unless it is in the mood to move. Very finicky.
Old Sep 21, 2015 | 02:50 PM
dn29626's Avatar
dn29626
Originally Posted by brian42
...I don't know if you priced any but you dodged a $110 bullet ($80 if you buy 3rd party)...
I priced them on ebay (used and new) over the week end, they ranged from $35 to $200.
Old Sep 21, 2015 | 04:49 PM
brian42's Avatar
brian42
Veteran: Navy
This is the one I got from 1A Auto for my 2003 with/automatic down for the driver's window:
2003 Ford F250 Super Duty Truck Power Window Switch Front Driver Side for Crew Cab Models at 1A Auto.com
Days after I got it I found an OEM one on Amazon (new) for $90. The switch works well and it looks just like the OEM one. My contact was too far gone to do any kind of repair/corrosion removal so I had no choice but to get a new one. The wrecking yards are a good distance to get to and most of them won't part out a door liner.
Old Sep 21, 2015 | 06:33 PM
tjc transport's Avatar
tjc transport
i ain't rite
<p>i would still take the door panel down and test the plug into the motor for power. this will tell you if it is the switch or motor.</p><p>if the relay is clicking, 99% chance the switch is good and the motor is dying.</p>
Old Sep 21, 2015 | 07:35 PM
dn29626's Avatar
dn29626
In the connector, no one mentioned which pins can be jumped. I will experiment there to see what happens.
Old Sep 23, 2015 | 07:35 AM
tjc transport
i ain't rite
<p>you don't jump pins. you unplug the motor and hook the pins to a volt meter. hit the switch and see if you have power. if you do, the switch is good.</p>
90paul250
Jun 10, 2018 02:55 PM
ddd7292
1997 - 2003 F150
Feb 10, 2013 03:34 PM
680276122
Sep 6, 2010 07:35 PM
SBastow
Aug 20, 2008 08:36 PM
fishnxtc
1997 - 2003 F150
Apr 8, 2003 11:50 PM
