Passenger Window Motor
Old Jan 19, 2008 | 07:36 PM
680276122's Avatar
680276122
Cool Passenger Window Motor
Guys,
Got a 99 Exp 4.6L. Anybody have problems with the pass. window motor? Won't go down/up. Besides checking the fuse under the dash, anything else that I'm missing (like a relay or something?). Also, for anybody who's done it, is it easy to replace?
Old Jan 20, 2008 | 06:12 PM
Gage2502's Avatar
Gage2502
It could be the switch, happened to my dads van.
~Gage~
Old Jan 21, 2008 | 10:52 AM
buzzard's Avatar
buzzard
The window regulator and motor are removed as an assembly.
1. Remove the front door trim panel.
2. Remove the front door radio speaker.
3. Remove the front door watershield.
4. CAUTION:
Support the window glass to avoid damage.
Raise and support the front door window glass to the full up position.
5. Disconnect the power window motor electrical connector.
6. Remove the window glass to regulator nuts.
7. Remove the motor and window regulator assembly.
1 Drill out the rivets.
2 Remove the motor and window regulator assembly.
8. Note:
Prior to motor removal, make sure the regulator arms are in a fixed position to prevent counterbalance spring unwind.
Remove the power window motor.
1 Remove the bolts.
2 Remove the power window motor.
Old Jan 21, 2008 | 08:49 PM
680276122's Avatar
680276122
Thanks Buzzard for the instructions. Now I just have to wait until the deep freeze lets up...!!!
Old Jan 22, 2008 | 06:32 AM
Yukon's Avatar
Yukon
Did you check the switch?
Old Jan 22, 2008 | 11:08 PM
04 powersmoke's Avatar
04 powersmoke
had a 99 expedition with the same problem except on the driver side. ended up being a short in the window motor.
Old Feb 6, 2008 | 05:22 PM
slaponte's Avatar
slaponte
I was able to remove my motor without removing the frame/regulator. (98 Expy, driver door). Here is how.
Once the door paneling is removed, and the rubber paper, below the door speaker you will see 3 small "dimples". These dimples are right over the location of the three screws that hold the motor in place.
I used a drill and a 1/2 inch hole cutter. I centered the bit on the dimple and cut a 1/2"hole that lets me see the head of the 5/16 bolts. I removed with a deep socket. If the fall between the metal and bracket I used needle nose pliers to get them out. There are three of them.
To put them back can be frustrating. I put some black electric tape over the hex head of the screw, and then press it into the socket. This will keep it from falling while you get it started.
I can take a pic and post, I still have it disassembled.
Before you go through all this trouble, in my case, this wasn't it. I seem to have an electrical issue somewhere else (OTD Relay?). Still researching. Before you go through removal you can test the motor. Just use a POS and NEG leads to the two wires (disconnect the plug inside the door). If you hook them up one way, it will turn up, opposite, it will turn down. If this doesn't work at all, the motor would seem to be bad. It is an easy test before drilling holes on the inside panel of the door. If the windows moves, then the motor is NOT it... and now you have to figure out what is it...
Old Apr 17, 2010 | 01:40 PM
davisenvy's Avatar
davisenvy
I followed these directions and they worked great. I have a 1999 EB Expy and there werent any rivits to drill out. Instead there were 3 little dimples that have to be drilled out in order to access the 5/16 bolts as noted above. Make sure the window is taped up before removing motor. In my case it was a plug and play event. Very good write up. Thanks for the info.
Old Sep 6, 2010 | 07:35 PM
JJ3's Avatar
JJ3
What if you cant get the window up? can yo still drill/plug/play? Does the window have to be in the up position?
homertwo
WTB - Parts & other
May 25, 2016 11:07 PM
Autoarcheologist
Aug 22, 2015 03:50 PM
7.3RP
1978 - 1996 Big Bronco
May 11, 2015 11:09 PM
chrono4
Aug 16, 2006 10:50 AM
vicv
May 1, 2005 04:26 PM
