Sponsored by: Real Truck
passenger window
Old Aug 20, 2008 | 07:58 AM
SBastow's Avatar
SBastow
passenger window
Passenger window will go down but does not always want to go up. Both drivers/passenger switch will work in down position but not up. After hitting switch several times it will work. I am not an electrical guru so any input would help.
Old Aug 20, 2008 | 08:27 AM
FTX's Avatar
FTX
Remove the door panel and clean the contacts on the window motor connector and make sure it is tight. Most likely moisture has gotten in there thru the lower window seal. Pretty common on an older vehicle. If that doesn't work you could remove the motor, open it up and clean the contacts and stator inside the motor... if that doesn't work replace the motor while you have it out :-)
This is for my 2005, but should be similar to your 99.
FRONT DOOR WINDOW REGULATOR MOTOR
Removal and Installation
1 Remove the window switch.
2 Remove the front door trim panel and watershield.
3 Tape the window in the full up position. (see pic)
4 Disconnect the window motor electrical connector. (see pic)
5 NOTE: Support the window motor while removing the window motor retaining screws. Remove the window motor screws and remove the motor.(see pic)
6 To install, reverse the removal procedure.
Old Aug 20, 2008 | 06:41 PM
ameinig's Avatar
ameinig
I have a 1999 that was doing this and it ended up being the window motor that was bad. Only took about an hour to swap.
Good luck.
Old Aug 20, 2008 | 08:36 PM
msgtg's Avatar
msgtg
Dave, nice answer Pal...Rep points to you!
Joe
Dpan63
Apr 9, 2014 05:42 AM
truckmonger1
Jun 13, 2010 09:20 PM
markvii91
Electrical Systems/Wiring
Mar 13, 2008 07:30 PM
jonnyfresh
1997 - 2003 F150
Jan 11, 2008 04:30 PM
jeffdoerr
Sep 9, 2005 03:43 PM
