PROJECT 53' Aluminator Build
So over the last few days I finished up the stainless exhaust. I made up some mounts to support it. To mount the exhaust I'm copying the mounts from Stainless Works. They are nice, but expensive and they are universal, so I'd have to modify them anyway. I have specific locations I want the mounts so I made my own. These are the blue snappers I'll use to insulate vibration. They are high temp. I'll also use weld on nuts from all star to mount to the frame.
Then with the exhaust temporary supported I measured and made my rear hangers. They will be two piece with a lower portion that will weld to the pipe, and an upper drop down that will mount t on the frame. I drilled out some 1/8" stainless stock with a hole saw on the drill press.
Then I end up with these pieces. One is for each side.
Then I bend them into shape. In don't have a brake. A trick I learned is to cut grooves in the part, then fold it. Because stainless is non magnetic its just harder to try and fiddle with little parts and weld them up. I use this trick for lots of stuff. You end up with am open corner that is easy to weld up. Just have to account for the metal thickness on the bends. The little arrows on the piece are reminders for me what side to cut on. The line scratched with a razor blade is the one I'll follow.
I did the same with the drop down strut. I wanted to stiffen up the flat stock so I bent it into a u shape. Then welded the open corner. The weld looks a little weird because I did it in little sections so I didn't warp it and turn it into a banana. My exhaust tips will be close to the tank and frame, so I want it fairly stiff.
Here is the finished part after I ground down the welds and cleaned it up a little.
Then I drilled out the frame for the the weld nuts and tacked them in place.
The rear mounts look like this on the frame.
Then I made a pair of mounts for the rear crossmember in a similar manner.
Then I pulled out the exhaust and fully welded it. Then reinstalled. With everything checked, double checked and then checked again
I tacked the mounts to the exhaust. I'll add one more set of mounts to my transmission crossmember after I make it. I did also cut in the stainless flex joints in the H-Pipe. The exhaust is mounted fairly rigid, so it will need some room to flex. One more thing is done and it feels good to check it off the list.
Edit* I should mention that SS is nasty stuff to weld so if anyone reads this and decides to try it, definitely do it in an open environment with a fan and a respirator. I have a little pancake half mask that fits under my welding helmet.
Thanks. David
Thanks. David
. No idea what was originally there. I welded in 1/2" nuts.
