Snowseekers V10 experience. "Chitty Deuce"
I believe so. The PO bought it and I didn't see any stickers or tags on just the stick, only on the tube and the stick was in the tube.
It may be possible to get just the stick. Go test drive a V10
I was cleaning up the "next step" parts and was trying to figure out a way to flush out the torque when I noticed something. I grabbed the magnet and probed the converter and out came a chunk. Then I saw another, tipped the converter up on its side and when the fluid cleared I saw more debris.
Even though the first one came out with the magnet (might have been the fluid tension holding it) the chunks are aluminum. The chunks are about the size of half a pea and then squished like a hamburger. I found about 4 of them down the shaft hole of the converter plus some smaller debris I see in there.
So what would you guys do?
I would think if the trans was bad I would have been told that. So I assume right now that the trans still works and something in the converter was coming apart. But is the trans still ok now? Does the fluid leaving the converter go threw the filter before going anywhere else? Do I drop the pan on the trans, possibly remove the valve bodies and whatnot and flush out as much as I can or see if there is any debris in the pan, put it together, get a converter and hope for the best?
I was thinking possibly the bushing on the trans snout may have been worn and the converter was flopping around so I already have a pump gasket, o-ring, and seal on the way.
Can a used converter be trusted?
The most I have ever done with an automatic trans is change a few springs and ***** around according to so instructions that came with a kit. Automatic transmissions are witchcraft to me, you spin a big drum in the front, something happens in the middle, and the output shaft turns.
I'll have to pull the pan and see what I can see. But I have some time off for camping now so you guys will have some time to debate this and what I should do. Hopefully you guys come up with a solution for me by the time I get back.
I am curious about the flow path of the fluid in the trans. Does the fluid go threw the converter first after the pump? Or does it go threw the trans first, then the converter? I would think centrifugal forces would keep any debris stuck in the converter (against the outer walls).
Maybe that "can of marbles" sound you read about some people having with their converters really is "marbles" rolling around in the converter? lol
Do the gas trucks/X's have the diode trasmissions? Any 00-03 4r100 work? What about the 2wd trans, can the tailshaft housing be swapped with the 4wd trans and work like they did in years past? V10 transmissions only or do the 5.4 transmissions work too?
Seeing how I can get a used trans "guarantied to work" for under $500 around me, the more I am thinking that is what I might want to do. The transmission comes witha torque converter too!
lol
Probably a good time to go with the correct Viton seal though, being it will be out.
Edit: Found a thread worth checking out.
https://www.ford-trucks.com/forums/1...to-a-f350.html
After over a week of fishing and having more time to think I believe once I find the funds I will just be getting the $490 trans and converter and just slap that in.
I have to pull the pan on the original trans and see if there is any metal in there just to get an idea of how much contamination got threw the system.
Camping was a great time. The 7.3 X ran flawlessly once again.
Thanks for the package and bonus.
