Snowseekers V10 experience. "Chitty Deuce"
Old Jun 25, 2015 | 08:39 PM
  #196
Snowseeker's Avatar
Snowseeker
Well that battery wasn't taking enough charge to even think about turning the motor over. So I yanked the battery out of the comet which has backward terminals compared to what the X takes. Turned the motor over for awhile, then after waiting turned it over some more and saw oil pressure come up. Checked the shrader on the fuel rail and nothing. Grab the "black label" 409 bottle which happens to have gas in it, squirt some in the intake and vroom! Open manifold V10! Then it died...
No fuel pressure, can't hear the pump but gauge shows 3/4 tank of gas enough to muffle pump sound? Any other known to cause the fuel pump to not work in these V10's?
I have to run out and check the inertia switch yet (should have thought of it right away). But I believe out of all the years that has only been the culprit like 1 time. The X has been sitting for awhile, maybe the pump just froze up?
Old Jun 25, 2015 | 09:11 PM
  #197
Snowseeker's Avatar
Snowseeker
I couldn't take it. Just now I ran out to the shop to check the inertia switch. Felt as though it was down and not tripped. Since I was at it I rearranged the 4 relays on the drivers side engine bay in the "two packs".
I turned down the radio in the shop, turned the key, and whats that noise? Gotta cycle the kay again to hear it better. Why that there noise be a fuel pump!!! I cycled the key about 5 more times till it sounded like it had pressure on it (bled out all the air). Crank the engine and VROOOM! Open manifold V10 running on its own!
I shut it off, came in, and grabbed a shandy.
Old Jun 25, 2015 | 09:17 PM
  #198
LivingLarge's Avatar
LivingLarge
Great work Andy, put some ear plugs on the wife and get ir out there driving around the yard! Take pics now that it's ready, you can start waxing tomorrow.
Old Jun 25, 2015 | 09:21 PM
  #199
Snowseeker's Avatar
Snowseeker
Here is the current state.
Old Jun 25, 2015 | 09:41 PM
  #200
LivingLarge
Yeah like I said, a little wax will hide all that
Seriously, you are a talented guy and I knew you would get this done in no time!
I just sent Stewart this PM... Stewart, I would like to pay for a 1 year membership for Andy ( snow seeker) how can I get that done?
Thanks,
Michael
Old Jun 25, 2015 | 11:44 PM
  #201
twigsV10's Avatar
twigsV10
Am I correct that it has been just a little over a month since you got the EX with a disassembled engine that was in boxes full of unmarked parts? And now now it has an working assembled engine and I assume replacement transmission installed? AND you appear to have a life other than working on the EX? Im impressed!
I did a in frame Engine overhaul on one of my tractors last summer and while it only really took a week of wrenching I spent several more chasing parts and getting heads and such machined to finish it. A John Deere 466 diesel isn't an exact comparison to a V10, with the wet sleeves and there head stand out on the JD which I spent way more time than I should have along with the rest of the motor checking tolerances the V10 has more than enough parts to assemble especially if they weren't labeled for placement. And that was my full time job when there was parts available to work with.
Old Jun 26, 2015 | 08:22 AM
  #202
Snowseeker's Avatar
Snowseeker
haha, thanks guys! Michael, I really appreciate the subscription gesture! There sure are some nice folks here! :beer:
Has it been a month already Twigs? That time flies! Yeah all my own stuff I have to do in my own time like this X. In fact I have a car coming today for exhaust so that means I have to get the X running and moving enough to back it out of the shop so I will be able to get the car in. No trans cooler yet so I just looped the lines at the radiator for now, not going on any trips soon so it should be fine. I also didn't want to stick the condenser or front end on till I get the trans cooler.
So I guess today I will put another 6 quarts of trans fluid in and see if I can get Chitty to move and some coolant in to see how many leaks I have. lol Still waiting for the PO to find the Y-pipe, radiator fan, and trans dip stick tube so I can't go for any sort of road drive yet. I will try and get a video today.
Old Jun 26, 2015 | 08:31 AM
  #203
Snowseeker's Avatar
Snowseeker
Oh yeah, I have two left over bolts and one left over nut. The nut is a 10mm, one bolt is a 10mm (which looks like an odd ball and may have nothing to do with the X) and one other short 13mm bolt. I did use a bolt or two out of my own stash for a couple things so these may be the ones I couldn't find when I needed them.
All the fasteners for the grill, support, and whatnot are in a separate container in the back of the X. Can't wait to get at those, that will mean it is button up time!
Old Jun 26, 2015 | 10:17 AM
  #204
Drunken_Unicorn's Avatar
Drunken_Unicorn
Doesn't it just sound neat with open exhaust?
Old Jun 26, 2015 | 11:25 AM
  #205
ExPACamper's Avatar
ExPACamper
On its way. You should have it by Monday
Bolts? I just found an extra one on my vent intake. Not sure how long it's been there, LOL.
Old Jun 26, 2015 | 01:43 PM
  #206
Snowseeker's Avatar
Snowseeker
Sometimes it can be funny to put a couple nuts or bolts on people cowls (plastic kind with pockets) just to mess with them.
Thanks again John!
Old Jun 26, 2015 | 01:44 PM
  #207
Snowseeker's Avatar
Snowseeker
It does! But way to loud for a trip around the block though.
Old Jun 26, 2015 | 01:47 PM
  #208
Snowseeker's Avatar
Snowseeker
So PO searches and says no transmission dipstick or tube, no radiator fan, and no exhaust Y-pipe which means of course no o2 sensors.
How do you loose a Y-pipe?
Old Jun 26, 2015 | 01:59 PM
  #209
Bently_Coop's Avatar
Bently_Coop
Sounds like header time.
Old Jun 26, 2015 | 02:33 PM
  #210
74Mav's Avatar
74Mav
With all the work you just did on that massive jigsaw puzzle of an engine, surely you can weld up a custom y-pipe...
