6.7 engine failure
Old Apr 16, 2015 | 05:34 AM
reelsharp100's Avatar
reelsharp100
6.7 engine failure
I would like to clear up some misinformation out there. My 2011 F350 crew cab lariat ultimate package with the 6.7 engine just came apart with 104,000 miles on it. I was driving my kids to daycare the other morning and the truck started shaking then the check engine light came on. I took it to the local ford dealer and they looked up the code in the computer and Ford has a service bulletin that if this code comes up to pull the glow plug and check compression. Needless to say the end of the glow plug had some damage and the cylinder is down compression. Guess what. The exhaust valve broke and I need a new engine. $15,000 for a short block. The truck has had nothing but ford products in it. I run fords def fluid, oil, filters, I even buy the windshield wipers from ford. Anyway, The truck was maintained to the tee and ford said they will do nothing to help out even though they know about this problem. I have owned nothing but Fords my entire life and this will be my last one. The biggest thing for me is that there was no warning, it just happened. I have read a lot online about this happening on the 450 and 550's but I would bet that in a few years when these trucks start to get more miles on them that u will see a lot more of this. Ford told me there is nothing they can or will do. I understand things happen and stuff breaks but it is hard to swallow that a $62,500 only lasts 4 years until the engine blows up. Buyers Beware!!!!
Old Apr 16, 2015 | 05:45 AM
ruschejj's Avatar
ruschejj
Sorry it happened to you. It is frustrating to say the least. Check your auto and homeowners insurance coverages for possible help.
If anyone ever asks I always tell them to buy the extended warranty on new diesel trucks. It an insurance policy that pays for itself many times over in most cases.
I know what you're going through, my 2011 truck (F250) dropped an exhaust valve at 122,000. The bill was over 26k back in 2012.
Old Apr 16, 2015 | 06:15 AM
mebe2k's Avatar
mebe2k
ouch...my 2011 just hit 80,000 a couple weeks ago...must get rid of it soon..I can't afford $20+K for an engine....same crap they (Ford) pulled with the 2.9L v6 in the 80's Ranger/Bronco II's..they had to have known they would start developing oiling problems after the cam bearings started to wear. Just like Ford knows the early 6.7's have defective valves..this has happened way too many times to be a fluke..they should be replacing the heads on the early 2011's...
seems like the early 2011's (built in 2010) grenade shortly after 100K..
Old Apr 16, 2015 | 06:36 AM
Gearitis's Avatar
Gearitis
first post and only 1 post, trolling?
Old Apr 16, 2015 | 07:28 AM
Painted Horse's Avatar
Painted Horse
Not sure that's true. I just sold my early 2011 at 145,000 miles and it was running great. To get an idea of what value to charge for the truck, I went out to the auto auction with my nephew and watched a several groups of 2011 Superduties go over the auction block. All were running fine and had in excess of 100,000 miles. Most of them were white XLT trucks, suggesting they came from oil field or some sort of fleet.
My nephew even bought a F-450 with 150,000 mile for a service truck. It was chipped and deleted and ran like a raped ape.
The point is I've seen a lot of these engines with well over 100,000 miles and they are still running great. I feel for the OP. Nobody likes a repair bill like that. Since it's out of warranty, I'd probably be looking for a good mechanic that can do a engine swap at non-Ford shop rates. Also there have been enough of these trucks totaled in wrecks, I suspect you might find a used engine to swap in cheaper than a new short block.
My nephew makes a living buying dodges with bad engines and putting cummins engines from wrecked trucks in them and reselling them.
Old Apr 16, 2015 | 07:47 AM
PlayersZ28's Avatar
PlayersZ28
My early build '11 F350 has extended warranty but it will expire mid-Jun this year. It only has 50,000 miles on it. I've heard of the exh valve issue but it doesn't look like if mine is going to fail it will happen during the warranty period. No rad failure yet either.
Old Apr 16, 2015 | 08:00 AM
my_crib_too's Avatar
my_crib_too
Welcome to FTE. Tough check to write for sure. Had you joined FTE earlier, you might have known about this issue in the 2011s and protected yourself with an extended insurance policy. I carry a policy on both vehicles to prevent having to write this big check. This is a very known issue in the 2011s.
Good luck. If you get to see the beast all taken apart, post a picture or two.
Again, welcome to FTE.
bruce...
Old Apr 16, 2015 | 08:54 AM
FordService's Avatar
FordService
Official Ford Rep
Originally Posted by reelsharp100
I would like to clear up some misinformation out there. My 2011 F350 crew cab lariat ultimate package with the 6.7 engine just came apart with 104,000 miles on it...
Welcome to the forum, reelsharp100; I want to look into this further and see what options there are to help. Send me a private message with your information and I'll get to work. I'll need your full name, best daytime phone number, VIN, current mileage, and servicing dealership. Thank you!
Crystal
Old Apr 16, 2015 | 11:29 AM
Ford_Doctor's Avatar
Ford_Doctor
I would be absolutely sure to contact Crystal as she has requested. I do no know who told you that Ford cant or wont do anything to help you. With 104,000 miles on a four year old truck you need to be sure to contact Ford directly and open a dialogue with them. You may be surprised. The early 2011 6.7L engines had a well known and documented concern related to the cylinder heads. I would bet that they may offer some assistance to you, but, you have to call them. (or PM Crystal)
Old Apr 16, 2015 | 11:38 AM
senix's Avatar
senix
This is a known problem on the early builds. Get back to Crystal or call the cust care # and ask for some help.
Old Apr 16, 2015 | 12:10 PM
sdetweil's Avatar
sdetweil
He is a new member and cannot PM yet.
we need to learn to look for that and advise folks the right way
Old Apr 16, 2015 | 12:28 PM
capt caper's Avatar
capt caper
What are the early builds? dates? serial numbers? mine was built (truck) on the line October 2010.
Old Apr 16, 2015 | 02:04 PM
TN22's Avatar
TN22
Same here...Mine built Oct. 2010
Old Apr 16, 2015 | 02:14 PM
senix's Avatar
senix
I think I have the TSB at home. Will look for it.
Old Apr 16, 2015 | 03:44 PM
capt caper's Avatar
capt caper
Were not talking about the chassis cabs? they had bad valves or head issues that I've read about. The pickups didn't..I don't know why but they were two different beasts.
