2017 superduty
Old Mar 13, 2015 | 11:17 AM
  #46
smoky_diesel's Avatar
smoky_diesel
Hope it has a D60 up front...
Ford really did well with the initial design in '99. The '05 update was an improvement. In my opinion, since then the styling is OK at best, getting worse each generation.
but the same was said in 1980, 86....
And my music taste is stuck in the 90's...
Old Mar 13, 2015 | 11:56 AM
  #47
System's Avatar
System
Prolocutor
There have been tons of camo spy shots showing a solid front axle.
Old Mar 13, 2015 | 12:53 PM
  #48
superrangerman2002's Avatar
superrangerman2002
Ford has their heads up their @&$&# if they think aluminum body panels on a SD will be well received.
Sales of the 150's are lagging by 30k units YTD. Several articles are already pointing out that Ford F150 may not recover this year as a best seller.
Old Mar 13, 2015 | 01:43 PM
  #49
Rattler1's Avatar
Rattler1
Originally Posted by RigTrash601
I agree. I personally like the '08 ton 10 front clip, with the 11 to 15 a very close second.
When did Ford actually "split" the body styles between the 150 & 250? 1997? It sure seems they're going back to the "old" way of doing things. I don't think that will be a wise decision, both trucks have a loyal following, I think the distinct differences in the models help with that. But,with both models going to aluminum bodies, probably a significant savings for Ford having to retool the factories to share alot of body panels.
They actually had 250's in both body styles for 97-99 I believe. Then they dropped the light duty 250 and kept the super duty model.
Old Mar 13, 2015 | 01:44 PM
  #50
watchluvr4ever's Avatar
watchluvr4ever
Originally Posted by superrangerman2002
Ford has their heads up their @&$&# if they think aluminum body panels on a SD will be well received. Sales of the 150's are lagging by 30k units YTD. Several articles are already pointing out that Ford F150 may not recover this year as a best seller.
That might have something to do with them being so ridiculously priced! Some of those F150's cost more than my pretty well optioned 2014 lariat F250 crew cab.
Old Mar 13, 2015 | 01:48 PM
  #51
Rattler1's Avatar
Rattler1
The 150 plant was shut down for several months to retool to the new body style. They put out around 1 a minute I think so that could explain the lack of sales...lack of trucks to sell.
Old Mar 13, 2015 | 01:54 PM
  #52
92F350CC's Avatar
92F350CC
Considering that there are 2 F-150 plants during normal operation and one of them has been closed for retooling...............
You can't sell what you're not yet producing.
Give it time, they'll pick up.
Old Mar 13, 2015 | 02:22 PM
  #53
System's Avatar
System
Prolocutor
If this is the actual picture, it's a good thing that it is out now. Look at it this way, it's a 2017 so if you don't like it you still have a full run of 2016 trucks to order or buy from. Choice is good...
Old Mar 13, 2015 | 02:55 PM
  #54
Andy Toth's Avatar
Andy Toth
Glad I bought a 2015! That looks like that hideous Silverado that my brother owns.
Old Mar 13, 2015 | 03:01 PM
  #55
roadkingfl's Avatar
roadkingfl
Andy, The only thing missing are the squared fenders...LOL
Old Mar 13, 2015 | 03:04 PM
  #56
chadjones99's Avatar
chadjones99
to ford : this looks like a chevy...
Old Mar 13, 2015 | 03:13 PM
  #57
SavageNFS's Avatar
SavageNFS
This looks really good...
said no Ford owner ever.
Old Mar 13, 2015 | 04:16 PM
  #58
Dim Sum's Avatar
Dim Sum
I think aluminum bodies are preferable over steel...but I've never owned an aluminum bodied vehicle. I can imagine though that those in the rust belt would prefer door corners and body corners that don't rust out after 5 years.
We will see...lets hope there are more compelling reasons to want a 2017 other than a new body.
Old Mar 13, 2015 | 05:06 PM
  #59
RigTrash601's Avatar
RigTrash601
I believe aluminum bodies will be the norm in a few years, regardless of the manufacturer, but they could've done better than this. Looks it was designed on an "Etch-o-Scetch"!
Old Mar 13, 2015 | 05:32 PM
  #60
Rattler1's Avatar
Rattler1
Aluminum will rot away just as fast or faster than steel.
