Sponsored by: Real Truck
Locking Hub Question
Old Mar 1, 2015 | 10:36 PM
jmtbiggin's Avatar
jmtbiggin
Originally Posted by redford
No, you have it backwards.
Looking at the direction of travel of the top of the hub....
Lefty Loosey (unlocK or auto in your case)
Righty Tighty (lock)
My owners manual says righty(cw) for auto,lefty(ccw) for lock. OEM hubs,typo in manual?
Old Mar 1, 2015 | 10:51 PM
AAubinoe's Avatar
AAubinoe
Hey I was not sure which direction to lock them either. I simply jacked up the front axle, put it in 4x4 and turned the ****. You will know when the hub and axle are locked! I marked it with a paint pen so that the spot on the dial and the spot on the outer ring are 'normally' aligned (2WD).
And my friend who is really into super duties once told me that the OEM manual hubs (atleast 99-04) are stronger then any after market hub (even warn).He told me that warn just look stronger as they have a metal face VS plastic. He did mud drag racing and was constantly blowing them.
Old Mar 2, 2015 | 05:53 AM
redford's Avatar
redford
FTE Leadership Emeritus
No it doesn't.
This is cut and paste directly from the manual.
Manual hubs: To engage LOCK,
turn the hub locks completely clockwise; to disengage the hubs
(FREE), turn the hub locks completely counterclockwise.
Auto hubs: To engage LOCK, turn the hub locks completely
clockwise; to engage AUTO, turn the hub locks completely
counterclockwise.
Old Mar 2, 2015 | 09:26 AM
bleeds blue's Avatar
bleeds blue
Do you have electronic 4 wheel drive (a **** on the dashboard) or manual (a lever on the floor)? From the factory, the manual and automatic hubs look similar, except the automatic hubs have AUTO and LOCK positions where the manual hubs have LOCK and FREE positions.
In either case, right (or clockwise) rotation will select the LOCK position. left (or counterclockwise) rotation selects FREE or AUTO.
Failure of the auto hubs is common, caused often by a vacuum leak or lack of maintenance. Replacement of the stock hubs with a Warn or Mile Marker hub is a fairly common modification.
So is the manual wrong? You just posted this on the first page.
Old Mar 3, 2015 | 04:20 PM
jmtbiggin's Avatar
jmtbiggin
Will post pic in a few days when I get home of my manual
Old Mar 4, 2015 | 08:34 AM
Gints's Avatar
Gints
Just reach behind a wheel and turn u-joint, you will now when hub is locked.
Old Mar 4, 2015 | 08:49 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
A really cool guy did this how to thread.
https://www.ford-trucks.com/forums/1...onversion.html
Old Mar 4, 2015 | 08:56 AM
Toyman's Avatar
Toyman
The guy in the thread listed above needs to relax and have a beer every now and then........
CoachGJ
Jun 20, 2012 08:25 PM
terryswafford
Mar 3, 2009 01:59 AM
diiennojs
16
Jan 21, 2009 09:11 PM
CounterMaker
Nov 2, 2006 07:47 AM
trakman
13
Nov 16, 2005 08:03 PM
