Sponsored by: Real Truck
Warn Hub Conversion
Old Jan 6, 2015 | 03:05 PM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
Warn Hub Conversion
Here you go.. an all encompassing hub change thingy.
First, make sure you have the proper supplies:
Then put your truck on your hoist. This step isn't really necessary, but I don't like having to bend down.
You have already verified the parts in the beer fridge, so verify the ones in the Warn Box. A couple of hubs, the lock thingys, snap rings, o-rings, etc.
If ll is good, it's time to reduce one part from the fridge. Then, grab a needle nose pliers, and remove the factory snap ring from the hub.
A couple of light taps to free any corrosion / gunk and they come off in your hand. (If more tapping is required, feel free to visit parts fridge)
This is what you have on your bench at this point:
(yeah mine were shot)
Now grab the locky thingy, and insert it into the hub.
Celebrate with parts from the parts fridge. Then go grab the large snap ring.
It is in three layers, so peel one up and get it into the slot.
Spin it around and in, it'll look like this. Whew, this is a lot of work. Getting thirsty, right? Good thing we're prepared with supplies.
Now, grab the lock out, and install the rubber o-ring into the groove.
Next, slide one of the hex bolts into one of the holes so you can get alignment of the lockout to the locky thingy.
Give it a couple spins, then install the rest making sure everything lines up while it's all still loose.
Once they are all in, use a wrench and snug them all up first, then tighten them. If you're thirsty like I was at this point, get some supplies.
I did the across thing like installing lug nuts, not sure if it was necessary, but I took the picture, so here it is.
Then tighten them all up according to someone's specs, I just used Elwood "That's Good" torque specs.
Get more supplies from supply fridge, and verify you haven't left anything on the bench.
Do the same thing to the other side. (that's why there are two sets of supplies in the supply fridge)
Set the truck back down on the ground, swing the hoist arms back, and wait for your buddy to show up, who won't, because he's making stew.
GO FOUR WHEELIN!
Old Jan 6, 2015 | 03:28 PM
pjerrn's Avatar
pjerrn
nice job! I think your supplies are running low though.
rep gun is jammed again!
Old Jan 6, 2015 | 03:29 PM
TheBigBee's Avatar
TheBigBee
MMMM Stew!!!
I had my own parts fridge this weekend! You saw the picture!
Old Jan 6, 2015 | 03:41 PM
garyoNC's Avatar
garyoNC
Are the Warn manual hubs better than the Ford OEM hubs? Are they available for the 2014?
Old Jan 6, 2015 | 03:42 PM
arctic y block's Avatar
arctic y block
Hey but ya forgot to lube them. To much supply's from
the cooler Ehh.
Old Jan 6, 2015 | 04:02 PM
hodge5's Avatar
hodge5
Optional step- clean the spindles up and paint them before installing the new hubs.
Old Jan 6, 2015 | 04:05 PM
BIGG HUBB's Avatar
BIGG HUBB
nice job, thanks for the details
Old Jan 6, 2015 | 04:20 PM
jimd1050's Avatar
jimd1050
BuhBye F450, I'm relaxin'
"Informative" is only "Good"...
"Informative AND Entertaining" is MUCH better!
Great Job... thank you! I think I need a beer...
Jim D
Old Jan 6, 2015 | 05:32 PM
Bigpipes 35's Avatar
Bigpipes 35
Awesome write up my friend Reps sent..
Old Jan 6, 2015 | 10:33 PM
Chad149's Avatar
Chad149
Never a dull moment around Elwood.
Definitely the most entertaining thread I've read, and yet very informative, in a long time!
Old Jan 7, 2015 | 06:49 AM
pjerrn's Avatar
pjerrn
seems like an oxymoron in the same sentence as Elwood.
Old Jan 7, 2015 | 07:10 AM
SDElwood's Avatar
SDElwood
Beer Fridge Finder
I don't know if they are necessarily 'better' but the ones on my truck were shot! Not sure about the 2014.
SDElwood's Avatar
SDElwood
Beer Fridge Finder
I feel the love.
Old Jan 7, 2015 | 07:55 AM
Sarge261's Avatar
Sarge261
The Warns are now available for 05-up trucks they are due to be released sometime this month, check the Warn web site.
Nice write up I keep many "spare" supplies in my fridge too.
Sarge
Old Jan 7, 2015 | 10:23 AM
Truckie256's Avatar
Truckie256
Question
the cooler Ehh.
Great info thanks....
where do you lube?
with what lube?
and someone else said paint spindles..... where? and just use rustoleum ?
