x Code/ATS C with With Extra Leaf Swap
Old Jan 31, 2015 | 08:42 PM
Drunken_Unicorn's Avatar
Drunken_Unicorn
Originally Posted by wpnaes
Sweet! Liking that bro lean.
All will be level when I do the rear.
Nose dive when breaking is gone. Omg omg omg. I'm sure the new shocks play a factor in that, but wooo!
I feel like I'm sharing too much y'all.... Lol
Old Feb 1, 2015 | 12:09 AM
Stewart_H's Avatar
Stewart_H
Originally Posted by Drunken_Unicorn
I can't wait to do the C's on the back!
Stewart
Old Feb 1, 2015 | 12:15 AM
Skip1970's Avatar
Skip1970
id like to get a set of them DD springs. i hear they are the softest ride yet.
Old Feb 1, 2015 | 11:14 AM
Immortal_Ben's Avatar
Immortal_Ben
Thank you. Just took it for a spin. Holy Hand Grenade of Antioch what a difference. I can't wait to do the C's on the back!
Did I take measurements? You bet I did! These measurements are from the ground to the fender.
Before:
Front Left: 38 1/4"
Front Right: 38 3/4"
After:
Front Left: 41 1/8"
Front Right: 41 1/2"
The best way to measure is from center of the wheel hub to fender. That takes out and wheel and tire size differences from rig to rig.
I run "modded" ATS X code replacements in the front. I had Junior over arch one add-a-leaf for me, which puts me at 27.5" in the front.
I have not yet had time to mod my ATS C_XL replacements in the rear, but right now it measures 26.75".
Old Feb 1, 2015 | 11:58 AM
Drunken_Unicorn
I think i have that measurement written down somewhere too.
I'll re measure with that method.
Old Feb 1, 2015 | 07:48 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
I did the x-codes on my old 2004, if i stumble on another set i'd replace my stock springs on my '02 in a heartbeat.
Looks great!
Old Feb 1, 2015 | 10:23 PM
WE3ZS's Avatar
WE3ZS
Looking forward to seeing it all finished front and rear, looks great so far!
Old Feb 2, 2015 | 04:20 AM
Skip1970's Avatar
Skip1970
Looks great!
where you get the xcodes akex? is the xcode listed on the springs itself?
Old Feb 2, 2015 | 04:13 PM
Drunken_Unicorn
I found this thread when I first started looking for my springs. I was able to verify the "X code" part number on mine with this list. Hopefully it helps.
https://www.ford-trucks.com/forums/1...e-springs.html
Old Feb 2, 2015 | 04:47 PM
Bite N Hold's Avatar
Bite N Hold
That looks awesome!!! I am NOT up for doing that work though!!!
Old Feb 2, 2015 | 05:32 PM
fordboy67's Avatar
fordboy67
That is one project on my to-do list when $$ allows!
Old Feb 2, 2015 | 10:08 PM
AlaskanEx's Avatar
AlaskanEx
Bleed Ford Blue
Craigslist...pure luck
Old Feb 3, 2015 | 02:42 PM
  #28
andym's Avatar
andym
The codes are not listed on the springs themselves. There are part numbers stamped into the steel from which you can sometimes decode into spring codes by googling or asking in here. Of course, if you manage to get them off the donor vehicle, you can just look at the sticker on the door jamb but often we aren't that lucky.
I also got lucky and randomly found a set of V/B codes on craigslist. The owner didn't know what he had. I had to get him to send me pics of the stamped numbers, and figure out what they were. I paid $170 for both sets.
Oh and I paid someone to do the installation of the springs (including the mod B part) and the MBRP exhaust. It was a LOT easier that way.
Old Feb 3, 2015 | 03:23 PM
  #29
Drunken_Unicorn
What did you end up paying to have someone install them?
Old Feb 3, 2015 | 03:34 PM
  #30
alex--taylor's Avatar
alex--taylor
I had somebody do the X codes up front, I don't have breaker bars, air, floor lift, jack stands, and on and on. I normally use the craft shop on the military base where we live, but didn't have the time to do it myself. I had a local shop do the front leaf springs, sway bar ends, tie rod ends, pitman arm, and an alignment when done. They charged $719 for 6.5 hours labor (remove and install), shop materials, and the alignment when done.
AT
