Seems with that philosophy (not criticizing, just observing) we should also replace shackle bolts/nuts; u-joint hardware, body mount bolts, seat belt bolts, anything that sees stress.
Stress is not the first issue, I think. It is stretching and resultant tensile strength which are the concern. Then stress becomes a secondary factor.
U-bolts get a great deal of torque applied to them.
I'm still looking for failures or problems reusing factory u bolts by someone with first hand experience.
I know the technical data behind them needing to be replaced.
So I will be the stick in your muddy pot! I have replaced a few rear ends in my day.. I have a great divorce attorney!
Ok back to reusing U bolts....If you know the Physics and scientific reason...then you should know the real world side of it....But if you do not......here it is....
If you can get them off in one piece, I would bet that the threads on the end of the ubolts will be boogered in someway or form.
That being the case the chances of you pulling the threads when you torque the nuts down are pretty high.
So what you need to ask yourself is are you willing to take a chance going down the road or being offroad and having a ubolt fail?
The hardware kit from ATS is about 70 an axle. I would rather spend the $ and have 0 issues!
BTW I have had old and new u-bolts fail on installation. Do not use the HELP brand ubolts unless you are in a pinch
I'm all aware of crappy Chinese u bolts, I am in the trailer repair business and probably swap 20-30 axles a year on trailers. About half the time they are drug on the ends and need cut, some are rusty and need cut off.
But, some come off nice and easy, as did the ones on my west coast 9-10 year old Excursion. The threads were as new in appearance and "Nut slack"
I've never had a trailer u bolt fail or loosen after being used / reused.
I don't think it's a bad idea, the cost is not great, I am just unconvinced to the point that they need to be replaced - specifically factory ones that came off nice with now obvious damage.
trailer ubolts are only under braking stress, a motorized vehicle is subjected to push pull of the axle trying to rotate while driving.
Skip that is a great point that I never considered, and idler axles don't even get the braking force.
Not to get far off the OP thread subject but when I put my used X codes off an F 550 I measured the shackle length at was an exact inch longer than the stock EX FRONT hanger.
Has anyone noticed that before?
Do all X codes applications use that? Do stock trucks with V codes have that?
And lastly for the guys who bought new springs can I assume they don't come with the shackle?
My new "ats x" code springs didn't come with different hangers. Am I in for a surprise when I install them?
I don't think your in for a surprise.
Maybe it's a 550 thing? I used the longer shackles because they came w the springs. Because they ride at an angle, and it's only an inch on one end (less factoring the angle) it may have got me a 1/4 inch higher at the fenderwell.
Mine were used, after some miles of driving I am dead at 2" higher compared too stock shackles and saggy springs.
Most guys w new X codes claim to be in the 2.5-3 inch higher range when first installed. Obviously the stock springs may sag differently on each vehicle so that difference in height can't be exact across all boards.
I have straight X Codes from ATS springs, I'm using the factory shackles. I've heard that some folks have reversed the shackles (turned them over) to get a bit more clearance versus new shackles. As I said though, I'm using stock shackles and I also have similar lift numbers in the front.
Mine did not come with shackles from ATS. I had no problem installing them with the stock shackles.
