First IDI
Old Feb 11, 2015 | 02:40 PM
  #121
madMatador78's Avatar
madMatador78
I Think there is 1 out of view on that picture.
Old Feb 11, 2015 | 06:01 PM
  #122
MOOSE_MACHINE's Avatar
MOOSE_MACHINE
Nice work Thomas. These old trucks are nice to work on. Except the weight lol
Old Feb 11, 2015 | 08:59 PM
  #123
bhambulldog's Avatar
bhambulldog
The inboard cylinders on each side share a coolant passage. (?)
Same with a Ford flathead exhaust outlets, V8 with three exhaust outlets for each side
Old Feb 11, 2015 | 10:43 PM
  #124
Todd Rhoades's Avatar
Todd Rhoades
Easiest quick check is continuity meter, remove wire from glowplug & check continuity between glowplug terminal & block, use diode setting on multimeter, should beep, this doesn't garuantee that they are heating properly, but it will pick out the ones that are definetly bad without removing all of them, drove IDI for 12 yrs, we have 3 only pulled them to check them once, use this method religously & have no problem with starts 6 out of 8 will get you started, #8 on IDI Turbo is MF so we don't even bother with it
avf100
Nov 15, 2016 06:43 AM
udsuth78
1978 - 1996 Big Bronco
May 13, 2012 09:38 PM
elgemcdlf
Indiana Chapter
Jan 31, 2012 03:03 PM
MARTYSTOWRIG
Washington Chapter
25
Mar 31, 2008 10:44 PM
Breech
Oct 16, 2007 10:00 AM
