It sure beats doing the head! Intake's about 10lbs or so.
The intake "gasket" on these is also the valley pan. Somewhat pricey, around $60. Be sure not to miss the square plug in the middle towards the rear, it has to come out to get the pan off. 3/8" ratchet works IIRC.
Small correction: I was just taking a closer look, (I know, I really have a life....), and see that it's not just the front of the heads that have this water port, it's every cylinder. All dead-end at the intake. At the gasket actually; it doesn't have the ports either.
Chevy, since you have nothing better to do, lol go look and see if the hole is situated in a manner that a person could tap it and pipe plug it. Curious is 7.3 has these ports.
Back of the gasket, only spot it seemed to be leaking
I snapped this off the injector, does the new o-ring kit come with new ones? I'm not sure if its plastic or aluminum...
EDIT: The return lines look quite original, had one literally break in my hand. Think I found the source of my hard start.
Don't scare me...lol. Do they just sit on there? Or is there sealer involved? I guess the better question is can I put sealer on it? Just for insurance? My plan was to scrape on it and get all the old gasket crap off.
Planning on doing water pump, injector returns/o-rings and coolant filter.
i just had an unpleasant surprise.
one of the guy from a few streets over stopped and asked me if i could burn a plate into the floor of his raggy chevy dump truck/snow plow.
sure.
so i go to fire up the bobcat welder sitting on the back of the 04, and the "water tight case" ain't.
water in the oil, and one cylinder full of water.
took almost an hour to drain the block. then i put 3 quarts of diesel in it, and drove to napa to get oil and an oil filter.
got home, drained the diesel, and filled it with oil. fired rite up and let it run for 5 minutes to get nice and hot.
now i have to cover it until the outside storage cover gets delivered.
if it don't snow tomorrow, then i will run it some more, and change the oil and filter again to get the rest of the water out of it.
yea, i know, it ain't as bad as your intake leak, but still not a good thing to find on a new machine i only had for a few months.
i am just glad he stopped by, otherwise it may have sat like that long enough to ruin the engine.
