Winter 14/2015 General BS Thread
Old Jan 22, 2015 | 12:30 PM
  #121
Sparky83's Avatar
Sparky83
whyd you delete the cooler?
Old Jan 22, 2015 | 12:58 PM
  #122
ponykilr's Avatar
ponykilr
They are known for failing and flooding engine crankcase with coolant.
https://www.ford-trucks.com/forums/9...r-failure.html
Old Jan 22, 2015 | 10:30 PM
  #123
Sparky83's Avatar
Sparky83
i heard of it doing them on the 6.0's but had never heard of them doing it on the 460's...
ive was planning to change mine on the 6.0 to an external one where it was air/oil vs oil/liquid... theres a kit out there to do it.. just havent had the need yet...
Old Jan 23, 2015 | 03:48 AM
  #124
77mud's Avatar
77mud
Finally had a few extra minute and went by dmv and passed my motorcycle skills test Wednesday and got my liscense. No more having to worry about looking over my shoulder for cops or worried bout rolling up on a road block. Plus the $15 was alot cheaper than a ticket for riding with out one.
Old Jan 23, 2015 | 06:18 AM
  #125
ponykilr's Avatar
ponykilr
VERY important to monitor the EGR cooler and oil cooler on the 6.0. With an Edge or a scan tool the engine oil temp and coolant temp should be checked frequently. There should be no more than 15* difference between the two. Once it starts creeping up the coolers are stopping up and getting ready to rupture. A new 6.0 is at least $15000 depending where you get it so PLEASE keep it checked or just go ahead and delete that stuff.
My friend Jeff has a 2003 6.0 with over 200k, never had a bolt turned on it. He keeps oil changed every 3000 and has kept coolant changed every year with the Ford Gold coolant. Temps are less than 5* apart every time its checked
Old Jan 23, 2015 | 08:12 AM
  #126
lilmatt119's Avatar
lilmatt119
Bob, the inserts in this kit are a little different. They're made specifically for spark plugs and are solid inserts, not a spring-type deal. The tap also is a one-process deal, no drilling required. You put the tap on the end of 3/8" drive or a 19mm socket and go to town on the spark plug port. The starter kit is only $35, comes with three different sized inserts also. If you have one of the modular engines, it's definitely advisable to keep the kit and some grease and other associated tools in your vehicle with you, so you can do this on the side of the road, instead of having to drop a couple hundred bucks on a tow bill lol
Old Jan 23, 2015 | 12:07 PM
  #127
Sparky83's Avatar
Sparky83
i plan to get rid of the stock coolers.. I think its got a pinhole leak on the exhaust side atm with as much as it smokes at start up... but waiting till march to confirm it... the conversion i plan to get separates the oil from the coolant.. Has a large passage for the coolant to flow through essentially bypassing how the stock oil cooler ran.. you actually end up deleting the internal one and gets piped externally to a small heat exchanger between the A/C condenser and Radiator.
Old Jan 23, 2015 | 12:53 PM
  #128
ponykilr's Avatar
ponykilr
Got my seat done!
Thread here https://www.ford-trucks.com/forums/1...ooks-good.html
Old Jan 24, 2015 | 09:56 AM
  #129
ubereal2's Avatar
ubereal2
Yup that license is going to be way cheaper than a ticket, and what a ticket may do to a guy's insurance. I did the same thing years ago when I got my first street bike. First, I failed the test with flying colors. Then after several months later I did get my motorcycle license. It's a suck feeling to get out on an enjoyable bike ride, only to be watching for the po po.
Old Jan 24, 2015 | 09:58 AM
  #130
ubereal2's Avatar
ubereal2
Originally Posted by lilmatt119
Bob, the inserts in this kit are a little different. They're made specifically for spark plugs and are solid inserts, not a spring-type deal.l
Yup, I know they are different
Old Jan 24, 2015 | 09:59 AM
  #131
lilmatt119's Avatar
lilmatt119
Cool, just making sure, there was a lot of confusion about that as I was researching my options. The whole ordeal was so easy I am half tempted to do it to the rest of the ports lol
Old Jan 24, 2015 | 10:14 AM
  #132
ubereal2's Avatar
ubereal2
I wouldn't, "If it ain't broke don't fix it"... If there's an issue with more cylinders, then yes.
Old Jan 24, 2015 | 10:16 AM
  #133
lilmatt119's Avatar
lilmatt119
Yeah that's where I'm stuck at lol. I'm too much of a tinkerer. Just got this FNS-9 and I love it so much, I literally can't find anything to tinker with on it, but my tinkering side keeps telling me there has to be something lol
  #134
77mud's Avatar
77mud
Yea I've had my permit since September but the wife rides with me alot so it will make things alot easier, and alot more enjoyable.
Old Jan 24, 2015 | 10:22 AM
  #135
ubereal2's Avatar
ubereal2
I haven't fired any of mine since we got together that hot day in July.
