Winter 14/2015 General BS Thread
Old Jan 19, 2015 | 09:05 AM
  #91
lilmatt119's Avatar
lilmatt119
Yeah in the Grand Marquis it's even worse, from what I've seen the entire dash has to come out. Definitely not something I want to screw with in my driveway, with not even a carport or a good shade tree. lol Closest thing I got is some gigantic butterfly bush my mom planted a long time ago lol
Old Jan 19, 2015 | 09:14 AM
  #92
ncheavymetal's Avatar
ncheavymetal
FTE NC Chapter
Glad to hear you are doing well and healing up Bob. Enjoy the buzz.
I have pretty much free reign on the internet at this site.
Now that's a scary thought.
Hope you get your ride fixed. I had a plug blow out on our old ford van. The typical 5.4 liter issue. Steel block, aluminium heads and loose plug. I got it heli-coiled and found it a new zip code.
Old Jan 19, 2015 | 09:37 AM
  #93
lilmatt119's Avatar
lilmatt119
Yeah, the 4.6 engines have the same issue. HeliCoil kit is apparently not just a fix but more of an epgrade. I think I will plan to keep the necessary pieces in the car in case of a future blow out.
Old Jan 19, 2015 | 10:03 AM
  #94
ponykilr's Avatar
ponykilr
I am going to cut my bumper to clear the new 37s and get it sanded and ready to paint.
Also gonna get the new cruise servo installed.
Old Jan 19, 2015 | 10:51 AM
  #95
Sparky83's Avatar
Sparky83
it is... even the mustangs have the same issue... mostly whats deemed the New Edge models (99-04)... prior to that they were steel heads.. but the base GT's still had steel even in the newer ones.. normally where the blow out problem happened was in the Bullitt's, Mach1's and Cobras... where the heads were either completely aluminum or steel with a aluminum threaded insert. Sad thing is ford doesnt really blame the heads.. theyre blaming bad installs of the plugs saying they werent tight enough when they were installed at factory..
down side the helicoil repair doesnt stop it from happening again.. quite a few of my friends had it happen again after having it fixed.. same cyls too..
Old Jan 19, 2015 | 10:56 AM
  #96
lilmatt119's Avatar
lilmatt119
Right, I have been reading another thread on FTE about the issue, and it seems the general consensus is Ford has no clue how tight the plugs should be anyway, and there are some reporting excellent results with 25-30ft lb on the plugs, even with the helicoil kit installed. I have little doubt it will happen again, as it seems to be more design flaw than anything at this point. However, being able to fix it for a few bucks a time (after i get the initial investment of the kit anyway) is a lot better than having the car down for a week while the heads are ripped off and drilled out and all that jazz, not to mention the money that entails.
Old Jan 19, 2015 | 11:43 AM
  #97
Sparky83's Avatar
Sparky83
exactly.. i dont even bother with torquing them myself... every time i have tried i just end up snapping the plugs in half... so i just crank them down till their snug tight.. seems to work..
Old Jan 19, 2015 | 11:51 AM
  #98
lilmatt119's Avatar
lilmatt119
Yeah that's kinda my motto, especially since I don't have a torque wrench lol.
Old Jan 19, 2015 | 12:08 PM
  #99
Sparky83's Avatar
Sparky83
i have 3.... i just which ill use on various things depending what it is that needs torquing.. got one for 3/8" drive 1/2"and 3/4"
Old Jan 19, 2015 | 12:24 PM
  #100
lilmatt119's Avatar
lilmatt119
Nice dude. I just have the most basic of hand tools at the moment, only time I've ever used a torque wrench was in auto tech classes. Me and my dad replaced many a plug and bolt never worrying with the specific torque, so old habits die hard lol
Old Jan 19, 2015 | 12:29 PM
  #101
Sparky83's Avatar
Sparky83
i use to be a mechanic.. so some of the tools are from back then.. others are ones ive collected over time.. the 3/4 tq wrench came from a needing to set a wheel bearing nut.. ones on the mustang are spec'd to be tqed to 256lbs... so figured thats an important bearing lets keep it on the car lol...only other ones i worry about are when im messing with drive train stuff, installing pullies or re-assembling the engines.. outside of that i couldnt care...
Old Jan 19, 2015 | 03:13 PM
  #102
ponykilr's Avatar
ponykilr
I have a Snap-on digital torque angle wrench. Does torque up to 250lbs and does angles for head bolts too. Very nice tool from when I was a dealership wrench.
Old Jan 19, 2015 | 04:08 PM
  #103
ponykilr's Avatar
ponykilr
Got bumper done. Thread here
Old Jan 19, 2015 | 04:11 PM
  #104
lilmatt119's Avatar
lilmatt119
Very nice man. You got a leveling kit or anything on it for those big tires coming up?
Old Jan 19, 2015 | 04:32 PM
  #105
ponykilr's Avatar
ponykilr
No, plenty of guys run em on 350s with just a trimmed bumper. If I don't like the way it looks I will either do an add-a-leaf or maybe a 2" RSK.
I like the big tire with minimum lift look. I never liked huge lifts.
