My Ford 300 Engine Build
Attachment 287629
Attachment 291146
Attachment 287768
Attachment 291147
Attachment 290545
The head weighed 75lb, and it was stuck on there really good. With it unbolted and the hoist lifting more than the weight of the head, it still took a fair bit of prying to get it off.
Attachment 291148
I labelled all the pushrods for reinstallation later, but I've now realized that I wasted my time as not only will I be needing different lengths, but I'm also switching out to 3/8" pushrods.
Attachment 291149
My block had the C6AE casting, which I'd never noticed before. So, concerned, I had to settle my worries and confirm that I had a 300. I did. I was happy.
Attachment 291150
I searched long and hard to find myself a 240 head. I don't live anywhere near a wrecking yard with anything pre-EFI era so it was actually a really big deal for me to find one. I put it through an electrolysis bath and it came out great. It's bleached look here is from the WD40 that was sprayed on it to get the water out.
However, when I pulled my head off the engine, I discovered that it actually already had a 240 head. It was a bittersweet moment. I was always looking forward to slapping on a 240 head to see what difference it would make. Turns out I already knew.
Attachment 291151
I bought these oversized valves from SI Valves as per a recommendation by a user on this forum. They're well made as far I can tell.
Attachment 291152
Here they are compared to an OEM valve out of my junkyard head. Quite a big difference. I probably should've gone up to a 2.02" valve as it has better flow up to 0.400" valve lift over the 1.94", but that's just me nitpicking. I'll survive.
Attachment 291153
In my recent post, I explained that SI actually discontinued their oversized valves for the 300, so I was forced to buy small block Chevy 1.60" exhaust valves. They're the same other than the 4.911" length. The Ford length is 4.810". I'll make them work.
Attachment 291154
Just goes to show how thousandths matter.
Attachment 291155
Perspective aside, you can see they're a bit taller.
They look sexy as hell together though!
Anyway, onto the bottom end. I got 240 rods for the engine, as this not only allows for a better rod length to stroke ratio or rod angle, which means less piston side loading and therefore less wear on the pistons and the cylinders, but their added length (6.795") compared to a 300 rod (6.210") allows the use of a smaller, lighter piston, (the pistons I ordered only weigh 386g each) which means easier high-RPM. The only downside to this is theoretical, in that with the longer rod it will take longer and also not last as long for the explosive forces of the compression stroke to have maximum leverage on the crankshaft, and since torque is measured by (force) x (distance), I will theoretically not have as much torque as I could've with the shorter 300 rods. What I mean by this is that with a short rod, it doesn't take as much downward piston travel for the rod to kick out at 90 degrees to the crank and apply leverage. Because it doesn't take as long for it to do this, the action starts earlier and therefore lasts longer. That being said, this engine is getting built up for power. I'm not going to notice this effect.
Attachment 291158
Here's a diagram I drew up of it. Should you go this route, you'll need small block Ford pistons meant for a 331/347 stroker as those have the smaller ~1.170" compression height. If you go with the early C5AE casting 240 rods like I did, the ones without the piston oil hole, you'll need pistons with a wrist pin diameter of 0.912". The C5AE rods are stronger. The C8AE oil-hole rods are prone to failure at the oil hole in high horsepower/high stress applications.
And this is what I'm left with.
I have much more for in stock for this engine. Stay tuned to find out. I will make every attempt I can at teaching as I go and also answering any questions you guys may have.
The pistons and the SBC valves were actually the first things I'd bought locally for my truck. It's usually significantly cheaper for me to order out of the States and import it.
Attachment 291117
And then the crank. I knew it would be heavy so for extra assurance I had my dad help me take it out to limit the chances of damaging anything. I put it on the bathroom scale. 70 pounds! Another surprise was the main cap bolts. They came out with a sucking noise as if there was a seal, and sure enough there was. Almost 50 years old and the bolts still have assembly lube on them. Amazing.
Attachment 291118
And now I'm left with a block. I hope to have my friend come over and help me take it off the stand so I can take it to the machine shop to have it hot tanked.
Attachment 291119
Great job ! Thanks
