NOT Ebay. If you want to go that route
send me the $80 + shipping and I toss
something in a box for you and we can
call it good. Then you can go to Ford and
get a good one with a 2 year warrantee.
I'll PM you my mailing address or my Paypal address.
I wish I had that fordparts.com link before. I live in Canada and my local dealer quoted me $460 for the EGR valve, plus a $40 core charge until I return the old valve. I had to resort to Ebay. I had a weird experience with my valve, it had to rotated 180 degrees to get it to fit the bolt holes, also I had a bent pin so needed to straighten that. It seems to be working good. I believe this was a part manufactured for Ford, but rejected as a second, I think it was assembled and clamped together out of phase to the base by this 180 degrees. I paid 120 plus shipping plus 30 duty into Canada. So for what it's worth, order ford.
Go into ford parts and select your truck and motor and then you will get the right one. I do know there are really only two EGR valves for 6.0, the earlier version for 2003 - 2004, and the later version, for 2005 and up. If it helps mine was 2005 and up and part is listed as 5C37-9F452-AA.
Sean
Well,
There are many choices...........
Autozone 3 choices.
2 of which have lifetime warranties. (Duralast and Dorman.........$160 & $204 respectively) NO CORE charge
1 does not have a lifetime warranty (Delphi---2 yr)
Then there's Rock Auto
They have MULTIPLE choices from $88.79 to about $145 (Delphi btw!)
The $88.79 is the DORMAN.
They also sell a Motorcraft branded one @ $143 and it has a core price to add on....
Some of the Rock Auto models are REMAN and some require a core return.
The Airtex is new and has no core (about $120)
Airtex is the OEM for many parts and the Ford part might just be an Airtex.
Advance Auto
Nearly the same choices and prices as Autozone with lifetime warranty and free shipping.
Having said all that, since the Autozone is close by and the thing is fairly easy to replace, I might opt for Autozone because of the lifetime warranty.
Even if the FOMOCO one is "better" I'd still get the one with the lifetime warranty because the Ford EGR valve is the one that failed in the first place!
