ROLLING COAL
Old Jun 16, 2014 | 01:04 AM
Edogsf350's Avatar
Edogsf350
Cool ROLLING COAL
when i acceralate im blowing black smoke until i hit about 10PSI of boost.
this has just started in the last 3-4 weeks. im looking for some suggestions on what i need to check? i just changed the oil and filters(OEM) and ICP and pig tail.
truck info is in my signature. any and all comments welcome.
Old Jun 16, 2014 | 09:03 AM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Boost leak, exhaust leak or stuck turbo vanes.
What is the EBP psi and VGT% during the acceleration?
Josh
Old Jun 16, 2014 | 10:22 AM
egregg57's Avatar
egregg57
Check and clean your EGR valve. It may be sticking or the valve could have failed.
Old Jun 16, 2014 | 11:47 AM
Edogsf350's Avatar
Edogsf350
Josh
EBP is inferd as it is a 03 engine. im certain there is a exhaust leak because i can smell it at start up in the cab. but not a big leak
VGT looks normal during acceleration but as you know it is a reported value not a commanded value. i can hear the exhaust sound change at idle when the vains
sweep from 85 to 14.
other than removing the turbo is there any other way to check operation?
and as suggested by egreeg57 i will check my egr valve
Old Jun 16, 2014 | 11:52 AM
Bullitt390's Avatar
Bullitt390
Normally a stuck EGR is white/grey smoke.
The engine is over fueling because the PCM is expecting more air than is being provided.
Stuck EGR would be too much air.
Josh
Old Jun 16, 2014 | 12:10 PM
Edogsf350's Avatar
Edogsf350
so a turbo removal and cleaning is in my future? unless there is another way to check the vein operation?
Old Jun 16, 2014 | 12:20 PM
Bullitt390's Avatar
Bullitt390
Since you noted a change in exhaust note at idle as the vanes sweep I would focus on a boost leak or exhaust leak.
Although if you're removing the turbo to change the y-pipe it might be a good idea to clean the unison ring in the turbo.
Josh
Old Jun 16, 2014 | 02:20 PM
egregg57's Avatar
egregg57
My failed EGR valve caused massive black smoke till I got to 10-12 PSI / 45-50 MPH and then eased off. I was new to the truck and deisels and it scared the living crap out of me. The EGR that was removed was badly coked up and INOP. The repair (new valve + labor) was about $350.00 at the time, If I remember correctly.
I may be wrong, but for the 15-20 minutes to pull, clean, inspect it, and put it back in, its worth a look I think.
Old Sep 21, 2014 | 09:50 PM
Edogsf350's Avatar
Edogsf350
so i just wanted to give a up date on this. I pulled my egr valve checked and cleaned it. It didnt look to bad. got a reman up pipe form josh and exhaust manifold gaskets from riff raff.
Spent last week end removing fender liners and exhaust manifolds. found I had a broken bolt in the passenger head #5 cyl. and got that extracted.
got the new gaskets and manifolds installed, worked my way up to the installing the up pipe. cleaned the vaines in the turbo, fought the exhaust leak at the mating connection on the turbo. finely got it all back together for the test drive just to find im still blowing black smoke
next step is to pressure test the CAC .
So if any one has any input i sure could use it
Old Sep 21, 2014 | 10:54 PM
mhoefer's Avatar
mhoefer
MAP tube and nipple into intake clean? IAT2 sensor cleaning? EBP tube cleaning and sensor? MAF sensor cleaning, IAT1 cleaning might also be necessary, I think your model may have this?
Also, after cleaning EGR, did you re-learn the EGR? Once you try all this, if still smoking, try unplugging EGR when the truck is off, see if that helps, if it does, could be a bad EGR valve too?
Old Sep 21, 2014 | 11:58 PM
Edogsf350's Avatar
Edogsf350
MAP hose and nipple checked today. i have the infered EBP . will check MAF which is also the IAT1.
EGR relearn? i haven't heard of that? please explain. i haven't totally ruled out the EGR valve its self
Old Sep 22, 2014 | 06:36 AM
2006powerstroke90's Avatar
2006powerstroke90
Are you boosting normally? Are you very sluggish upon take off?
Old Sep 22, 2014 | 08:06 AM
Toreador_Diesel's Avatar
Toreador_Diesel
FTE Leadership Emeritus
That's what the problem was on my truck. It would belch out black smoke like yours until the turbo caught up in the higher RPMs. I found the MAP sensor nipple partially clogged on my truck. A WD-40 spray straw cleared the hole, I reset the KAM, and my truck drove night and day better. My mileage and power are up too.
Old Sep 22, 2014 | 10:54 AM
Edogsf350's Avatar
Edogsf350
it seems to be building boost normaly
Old Sep 22, 2014 | 10:55 AM
Edogsf350's Avatar
Edogsf350
i checked the map hose and nipple yesterday when installing the turbo
Unrealo4
Mar 2, 2011 11:39 AM
scameron
Sep 17, 2010 07:46 PM
f350fixaliter
Sep 5, 2010 04:33 PM
PsD007.3
Jul 29, 2009 02:58 PM
PsD007.3
Jul 25, 2009 01:51 PM
