Sponsored by: Real Truck
Lost keyless entry code for 2005 F-250
Old Sep 1, 2014 | 08:24 PM
Padlock's Avatar
Padlock
I can't remember my door code and don't want to take it to the ford dealership and pay. I know there is a code up under somewhere but I can't find it? 2005 f-250 lariat. Any step by step instructions would be greatly appreciated!
Old Sep 1, 2014 | 08:48 PM
Iaff113's Avatar
Iaff113
Their has been many threads on it. Search here or over in the 6.0 section.
Old Sep 1, 2014 | 09:38 PM
PaxtonShelby's Avatar
PaxtonShelby
Once you find it, hide it somewhere in your cell phone contact info.
Old Sep 1, 2014 | 11:33 PM
Yahiko's Avatar
Yahiko
It's on the VSM behind the radio. But you can't
get at it that way. I read something about pulling
the little storage tray out next to the driver and using
you smartphone to take photos up in the space. Also
there was something about moving the insulation to
get a clear look at the number. The other really easy way
is to use a inspection scope to look up there.
Try this link to get more info on the how to.
Ther eis a second link inside this that you want to look at.
https://www.ford-trucks.com/forums/1...-location.html
Sean
EDIT : USE this link
https://www.ford-trucks.com/forums/s...1&postcount=22
Old Sep 2, 2014 | 12:53 AM
MisterCMK's Avatar
MisterCMK
Ae will retrieve the code
Sent from my Telegraph using IB AutoGroup
Old Sep 2, 2014 | 05:15 AM
Just Strokin's Avatar
Just Strokin
From 2015 SD Owner's Maunal
Displaying the Factory Set Code
Note: You will need to have two
programmed passive anti-theft keys for this
procedure.
To display the factory-set code in the
information display:
1. Insert a key into the ignition and switch
the ignition on for a few seconds.
2. Switch the ignition off and remove the
key.
3. Insert the second key into the ignition
and switch the ignition on.
The factory-set code will display for a few
seconds.
Note: The code may not display until after
any other warning messages first display.
Old Sep 2, 2014 | 10:36 AM
King-bRanch's Avatar
King-bRanch
Larry, Iam quite sure the 05-07's don't do this ^^^
The dealer gave me my OE Code & they didn't charge a dime, call em & ask
Old Sep 2, 2014 | 12:07 PM
Yahiko's Avatar
Yahiko
procedure.
key.
seconds.
You right that they don't. Because no PATS
But it is a neat trick for the newer ones that do.
Sean
Old Sep 2, 2014 | 12:21 PM
David7.3's Avatar
David7.3
Do you have your factory manual, its on the back of a card in the pouch.
You can always try 11311 they all came with that number till you put your own in, you would be surprised how many fords that still works on, I got into a lady's explorer in a 7-11 she locked her keys in.
Old Sep 2, 2014 | 01:50 PM
asdrew's Avatar
asdrew
I think I found the most detailed info in the Excursion section.
IN my 2005 F250, the code is plain as day if you drop down the driver side storage tray and shine a flashlight toward the firewall. It is on a big sticker on the module back there.
Old Sep 2, 2014 | 06:26 PM
05F250DSL's Avatar
05F250DSL
I had to move some of the white insulation to the side to view mine but I did pull the radio to make it easier
brian2way
Jun 18, 2009 04:24 PM
at4rxj
Mar 18, 2009 06:46 AM
timsexcursion
Aug 21, 2008 12:47 AM
fin1
Feb 19, 2007 01:11 PM
20MustangGT01
Apr 12, 2006 01:29 AM
