Sponsored by: Real Truck
Keyless Entry Code ?
Old Feb 16, 2007 | 10:23 PM
fin1's Avatar
fin1
Question Keyless Entry Code ?
Where is this computer module located to find the 5 digit keyless entry code? I just bought a 2005 F350 Lariat SuperDuty but need to get code from Ford dealer who wants $60.00 to get it. I have heard u can find it on the module.
Old Feb 16, 2007 | 10:44 PM
shockwave6's Avatar
shockwave6
check your owners manual and paperwork for the security card it has the code on it or remove the panel under the steering wheel and get a mirror and flash light and look up and to the right under the white foam you should see it in large font on the module
Old Feb 17, 2007 | 08:59 AM
SS2001's Avatar
SS2001
Here's how I found mine: Take the 2 screws out of the bag holder thing, pull it off carefully. Look in the hole with a flashlight, slightly up and to the left there is a box mounted to the firewall with a white sticker on it. The code will be the 5 digit number in larger font than the rest kinda off to itself. Mine wasn't behind the insulation like others have said (2004 F250 SD). Hope this helps.
Old Feb 18, 2007 | 07:57 PM
fin1's Avatar
fin1
can't find module?
I still can't seem to find the code anywhere? is there lots of wires comming off the module? I see a black box but no sticker on it anywhere? 2005 F350 Lariat
Old Feb 19, 2007 | 07:12 AM
SS2001's Avatar
SS2001
Maybe they changed it in 05?
Old Feb 19, 2007 | 11:05 AM
shockwave6's Avatar
shockwave6
Its a white box try removing your stereo to find it
Old Feb 19, 2007 | 11:21 AM
cmarrero76's Avatar
cmarrero76
I just had to look for mine. The computer is behind the radio. Remove the access panel to expose the fuse box. you might need to move some of the insulation out of the way, but it is way up there, directly behind the radio
Old Feb 19, 2007 | 11:33 AM
fin1's Avatar
fin1
how do i remove the radio?
Old Feb 19, 2007 | 11:42 AM
cmarrero76's Avatar
cmarrero76
radio removal
I think you need some u shaped pins, Like these.
Old Feb 19, 2007 | 01:11 PM
Viper1837's Avatar
Viper1837
If you pull open the storage compartment just below the stereo you can see it. It is up against the firewall. Get a flash light and look straight up the firewall almost behind the stereo. Big numbers.
