Sponsored by: Real Truck
2005 F250 Keyless Entry
Old Jun 17, 2009 | 06:27 PM
brian2way's Avatar
brian2way
Just purchased a used 2005 with the keyless entry mounted on the drivers side of the door. Seller did not recall what the code was/is. Is the code located inside the vehicle somewhere. I looked under the dash, behind the glove box, under the seat belt system with no luck. Any suggestions as opposed to taking it back to the dealer and paying big $$. Default code may also help. Thanks
Old Jun 17, 2009 | 08:48 PM
F350-6's Avatar
F350-6
Welcome to FTE. Seems like I remember reading there's a sticker up behind the radio on the firewall that has the code on it.
Old Jun 17, 2009 | 11:28 PM
EXv10's Avatar
EXv10
Lots of info on it here. Do an advanced search.
Old Jun 18, 2009 | 02:46 PM
brian2way's Avatar
brian2way
Found the number
I pulled the dash and found a bosch module (directly below the radio) with a 5 digit code. I tried the code and it worked!!. I was also able to change the code.
Thanks for your help.
Brian
Old Jun 18, 2009 | 04:08 PM
BPofMD's Avatar
BPofMD
Veteran: Navy
You did NOT CHANGE the code, you added your own code to the system. If the codes get wiped for whatever reason, your code will be deleted, but the original will remain. Either can be used to unlock the door.
Old Jun 18, 2009 | 04:24 PM
brian2way's Avatar
brian2way
I did not try the old code, but that makes sense. Good information to know.
Thanks for the post.
Brian
crozz
Iowa Chapter
Mar 7, 2017 12:23 PM
crozz
2004 - 2008 F150
Sep 26, 2016 08:16 AM
Padlock
Sep 2, 2014 06:26 PM
excursion2001
General Automotive Discussion
Feb 9, 2004 10:10 AM
Motorcraftsman
Jul 19, 2000 04:00 PM
