Reliability
Old Apr 30, 2014 | 07:35 PM
  #46
lurch460's Avatar
lurch460
That's a nice looking truck to start with. I have a set of grill inserts that will make it look a lot nicer, sitting on the shelf collecting dust. Think they are aftermarket but if you got the shipping covered, they are yours.
Old Apr 30, 2014 | 07:58 PM
  #47
Lloydable's Avatar
Lloydable
Originally Posted by Filthy Beast
Looks like you have enough pedal free play......To me, that (chirping?) noise sounds like a throw out berrin.....or an input shaft berrin.
Pull the boot off the clutch fork...you should be able to peek in at the throw out berrin and the shaft......you might be able to get a couple fingers in there too. What are your observations?
The chirping is my drive side mirror bouncing in and out of the door. The noise I am hearing is more like a whirring. When I start pushing the clutch in it changes. Maybe it's normal? I will take that a part this weekend and get back to you. I would also like to look at the linkages because I think my shifter is a little sloppy.
Originally Posted by lance65
To the OP, congrats on the truck!
Thanks very much!
Hey thanks! I'd love to see a photo of them, and my zip is 80487. Very interested.
Old Apr 30, 2014 | 08:37 PM
  #48
lurch460's Avatar
lurch460
I hate uploading pics hold on let me go read what i need to do aagin
  #49
lurch460's Avatar
lurch460
http://i1284.photobucket.com/albums/...psa4aea679.jpg
Old Apr 30, 2014 | 08:47 PM
  #50
lurch460's Avatar
lurch460
They are not perfect and they are Chinese, But some cleaning and touch up paint, they will look good. Nothing is broken on them. Let me know if interested.
Old Apr 30, 2014 | 09:01 PM
  #51
Lloydable's Avatar
Lloydable
Yea! I definitely want them assuming shipping is reasonable. Thanks so much!
Old Apr 30, 2014 | 09:12 PM
  #52
lurch460's Avatar
lurch460
Okay pretty sure I have a box theyfit in. PM your address and whats reasonable for shipping for you. I would rather see them on a truck than hanging on my wall collecting dust.
Old May 1, 2014 | 09:16 AM
  #53
Lloydable's Avatar
Lloydable
Pm sent. Let me know if you didn't get it! Thanks again!
Here is the video again so people don't have to look for it. So I am troubleshooting the whirring/whining of the clutch that you can hear change wen I depress the clutch pedal. It does it in all gears and is loudest with the clutch out. I am going to take the shifter apart this weekend as suggested in an earlier post to look at the bearings. Any other things to check....
http://youtu.be/nLUutswvUf4
Old May 1, 2014 | 12:23 PM
  #54
Filthy Beast's Avatar
Filthy Beast
Originally Posted by gatorfor88
^^ that sounds dirty for some reason. Maybe its just my d.o.m.s.
I was thinking the same thing then I saw he is from the state of Massivetwosh1ts! Thats the way some of 'em talk! I had a friend from there and he talked just like that!
Awww.....youse guys say the purdy-est thangs!
To the OP...congrats on your vehicle, have fun with it.
Old May 3, 2014 | 01:48 PM
  #55
Westcoast Highboy's Avatar
Westcoast Highboy
As was already posted, I would put my money on clutch throw-out (release) bearing or transmission input shaft bearing and/or pilot bearing going bad.
If the noise does not change much when shifted into 4th gear then it is probably the throw-out bearing.
In 4th gear the input shaft is locked to the output shaft which usually takes the load of the input bearing and causes it to quiet down significantly if it is the source of the noise.
Divorced transfer case makes pulling transmission a little easier. Plan on replacing clutch disc and pressure plate while you are in there. If transmission bearings are suspect at all, change them out while you have it apart.
Welcome to the world of old Ford trucks. At least they are simple to work on and parts are readily available at reasonable cost compared to late model trucks.
Old May 3, 2014 | 02:06 PM
  #56
rougeriver's Avatar
rougeriver
http://i156.photobucket.com/albums/t...psca420f7f.jpg
http://i156.photobucket.com/albums/t...ps770e1c96.jpg
http://i156.photobucket.com/albums/t...ps097d973a.jpg
http://i156.photobucket.com/albums/t...psb49b64e6.jpg
http://i156.photobucket.com/albums/t...pse3e77341.jpg
Your photography is wonderful! I really like these photos! Your truck looks fantastic, and the settings can't be beat! Gorgeous!
David
Old May 4, 2014 | 01:45 AM
  #57
Lloydable's Avatar
Lloydable
Thanks for the input! it does not change in fourth gear, so I suspect you are right. I am amazed at how small and simple these transmissions are. Planning to take it apart maybe in June.
Would this be a good kit?
http://www.ebay.com/itm/Ford-NP435-435-Transmission-Overhaul-Rebuild-Kit-64-87-/200499670304?_trksid=p2054897.l4275
Can you tell if it has the bearings I need?
What would you recommend for clutches?
Thanks,
I am blessed to call that my driveway, looking over the land that the ranch I work for owns!
Old May 4, 2014 | 10:12 AM
  #58
lurch460's Avatar
lurch460
The throwout bearing isnt in the transmission, its part of the clutch. It goes on the fork that goes into the bellhousing. While the transmission is out, have your flywheel surfaced and throw a new clutch kit in it and be down with it. THese 4 speeds are easy, strong and reliable. If you have a friend that transmission can be out in about an hour if you have a good plan.
LEt me know when those inserts get there.
Old May 4, 2014 | 10:48 AM
  #59
Westcoast Highboy
Pretty much any brand name replacement clutch assembly will be fine. Just don't buy the cheapest one.... Depending on the kit, it may include a throw-out bearing or you may have to buy that separately.
That transmission rebuild kit shown in your post looks pretty decent. Its usually a lot cheaper to buy the complete kit as opposed to purchasing individual parts. These transmissions are pretty straight forward to rebuild and I am sure there are plenty of how-to guides on the net.
Take lots of photos during dis-assembly if you are not familiar with these transmissions as that will make life much easier when putting it back together.
Your truck looks pretty good (although I admittedly tend to be a bit biased towards highboys )
Old May 4, 2014 | 01:05 PM
  #60
lurch460's Avatar
lurch460
I have always used LUK clutches, never had any issues. When I changed the factory clutch in my 97 f150 it had a LUK in it from ford.
