HPOP Removal trouble
Old Feb 24, 2014 | 12:53 PM
rickmanl1's Avatar
rickmanl1
I am having issues removing the bolt under the hpop next to the IPR. It seems to be frozen. any thoughts on what I can do to get it out?
Old Feb 24, 2014 | 02:04 PM
BigAlsPSD's Avatar
BigAlsPSD
You could try tightening it a little too, to see if it will break the threads loose...
Old Feb 24, 2014 | 02:18 PM
Tugly's Avatar
Tugly
When I get a stuck bolt - fire works (but not in this case), tightening (as mentioned), or "shocking" the bolt. A light rap with a hammer to shock it, but not a reefing slam - that last part is the makings of a broken bolt.
Old Feb 24, 2014 | 02:25 PM
duck fan's Avatar
duck fan
Because racetruck
A good 6 point socket and a bot of force. Those HPOP bolts always seem to take some work to get them to break free and then its easy from there.
Old Feb 24, 2014 | 05:38 PM
scotttahoe's Avatar
scotttahoe
Why not spray some penetrant on it.
Old Feb 24, 2014 | 07:49 PM
retiredsparky's Avatar
retiredsparky
In addition to the above ideas, a pneumatic ratchet will provide a small amount of impact or a battery powered impact tool used on low speed will sometimes break loose those stubborn small bolts.
Old Feb 24, 2014 | 09:13 PM
SaintITC's Avatar
SaintITC
First make sure you've got the right 6 point socket, I can't remember if these are SAE or metric. Get a long breaker bar, and while gently pulling on it, tap the end of the bar with a hammer (like you're nailing the bolt)
Old Feb 25, 2014 | 07:37 AM
rickmanl1's Avatar
rickmanl1
thanks
I will try some of these things this weekend. I do not have a lot of room to get at it. cannot even see the bolt. if yo have ever removed the HPOP you will know that one bolt is hidden and it is all feel. I know I have the right socket, I have removed this bolt before. the other one comes right out. this one will not move. I will update everyone soon... keep the ideas coming. one of them has to work... thanks again all...
HelenT
Oct 1, 2018 12:19 PM
xtremexj
Aug 12, 2013 03:55 PM
mdr617
Dec 16, 2010 11:07 PM
BSF350
1983 - 2012 Ranger & B-Series
Dec 3, 2010 05:29 PM
jlang
Jun 20, 2009 11:12 PM
