Gauge or Obd Trans Temp ?
Old Feb 8, 2014 | 04:47 AM
bstarz40's Avatar
bstarz40
Installed a 3 gauge piller mount glow shift max tow gauge set. the trans temp from the gauge is 20 deg off lower than the ecm reading. With the stock tranny being soo sensitive to temp which reading should I use. I know , but 20deg does matter, Right. or am I being to ****.
Old Feb 8, 2014 | 06:23 AM
Tugly's Avatar
Tugly
I have a laser thermometer for things like this. I aim around under there, looking at all the different parts of the vehicle I can access externally. I can look for temps on brake rotors, fluids, bearings, U-joints, etc....
You might be able to settle the dispute between the gauges with that third opinion, but it's still a good question on the forum for those in-the-know about transmissions. Sadly, I know next to nothing about the inner-workings of the device that takes all the oomph from a 7.3L and puts it to the wheels.
Old Feb 8, 2014 | 06:48 AM
90pioneer's Avatar
90pioneer
My isspro evo2 gauge matches my areoforxe gauge ecm trans temp reading almost perfectly.
You might have a bad sending unit...
Old Feb 8, 2014 | 07:05 AM
white Buffalo's Avatar
white Buffalo
It's pretty normal/common to see a difference in the two readings. I wondered the same a few years ago when I noticed it in my F-250. The gauge is reading from the test port on the passenger side of the tranny and the PCM is reading from the internal sensor.
From Mark K.
Originally Posted by Mark Kovalsky
A 20°F degree difference between the test port and the internal sensor is normal. Sometimes the test port will be higher, sometimes the internal sensor will be higher. It depends on operating temperatures.
Old Feb 8, 2014 | 08:24 AM
cuttn4fun's Avatar
cuttn4fun
I see the same
With my autometer trans temp gauge I see the same as you are reporting. When using the torque app the two are exactly 20 degrees different. my concern was that the PCM's reporting temp is always 20* higher than the analog.
Old Feb 8, 2014 | 09:12 AM
t.scottNDU's Avatar
t.scottNDU
My AutoMeter trans temp gauge and DP Infinity show about a 20* difference as well.
I saw a post by Mark K. in my travels where he stated that the stock sensor was very accurate, it's just the in-dash gauge that isn't. So, I usually go off of the PCM reading.
Old Feb 8, 2014 | 09:46 AM
Mark Kovalsky's Avatar
Mark Kovalsky
Frmr Ford Trans Engr
From Mark K.
Yep, that all correct. The sender in the test port is in a different location than the internal sensor. Temperatures vary across the trans, that's normal. You do t have a bad sender, you have a normal temperature distribution.
Old Feb 8, 2014 | 03:04 PM
bstarz40's Avatar
bstarz40
So I should go with the higher temp.
Old Feb 8, 2014 | 08:41 PM
snknby123's Avatar
snknby123
As will I. My analog gauge is 10 degrees low until it reaches saturation based on ambient temp/load. I will be dumping my analog gauge and using the Torque app to monitor the more accurate internal temp.
Old Feb 8, 2014 | 09:41 PM
ScaldedDog's Avatar
ScaldedDog
Go tow up a mountain. You'll find that the two readings swap positions, though I can't tell you why. As Mark said, sometimes one is higher, sometimes the other one is.
Mark
Old Feb 8, 2014 | 11:40 PM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
90pioneer... you are the perfect person to ask the following questions of, since you have used both a digital Aeroforce and an analog EV2 for reading the same thing (TFT).
- Which gauge is easier for you to monitor and understand at a glance?
- Which gauge is easer to read/see at night?
- Which gauge is easier to read/see during the day?
- Can the Aeroforce be set to automatically inverse the LCD when the lights are turned on?
- Can the Aeroforce illumination be dimmed in concert with the rest of the IP illumination?
The decision about which gauge to use should factor in the ergonomics of being able to monitor the data in all driving conditions, with as little driver involvement as possible. The readability issues might be more important than small temperature differences, because if it is too much of a hassle to see or understand the gauge at a glance, then the length of time the transmission is operating at an elevated temperature without the operators awareness might be worse than a lower reading that is easily seen and instantaneously comprehended.
Old Feb 9, 2014 | 12:03 AM
SARDiverDan's Avatar
SARDiverDan
My isspro reads 10 degrees cooler than the reading I get with scan gauge II. My system holds about 9 more quarts than stock so it stays relatively cool for the most part.
Old Feb 9, 2014 | 12:16 AM
Y2KW57's Avatar
Y2KW57
Top Answer: 5
Top Answer: 10
The extra 9 quarts equals 2.25 gallons.
The transmission pumps fluid at about 1.2 gallons per minute.
Therefore, in less than 2 minutes, that extra 9 quarts will all get pumped thru the heat generating torque converter and get just as hot as the rest of the fluid.
By contrast, the 6.0 tranny cooler in your sig is an effective means of REMOVING heat from the fluid, not just delaying for a couple minutes how hot all the fluid gets.
jasonodsky
Feb 28, 2011 01:14 PM
Shake-N-Bake
26
Jul 4, 2010 02:16 PM
shark1979
Aug 3, 2009 11:23 PM
heathrunkles
20
Jul 31, 2008 06:06 PM
mickelsons
Sep 9, 2004 04:51 PM
