Sponsored by: Auxito
Starting Issues
Old Jan 28, 2014 | 08:28 PM
eramone1's Avatar
eramone1
Starting Issues
I have a 1998 Ford F-150 4wheel drive extra cab. I have been having starting issues with it. It will start fine in the morning. But if I go on a short trip, say to the store, and then try starting it again, it takes forever(5 minutes) to get it to start again. I heard from a friend, that the catalytic converter could be getting to hot, which in turn gets the starter hot which may cause it not to start. Anyways, any advice would be appreciated. Especially if these symptoms sound familiar. Thanks
Old Jan 28, 2014 | 09:04 PM
aaronfrey58's Avatar
aaronfrey58
I had a truck a few years ago with the same issue it was a 98 4.2 I believe.. but it would not turn over...turns out the + cable that bolts onto the starter broke off...if urs is starting to come off, or is corroded, this could be causing the issue..I put a starter in this truck too and I believe it was re designed in some way ( I'm not sure if it would apply to your issue but I would look in to it)
Old Jan 29, 2014 | 06:37 AM
projectSHO89's Avatar
projectSHO89
You need to define what that actually means as that generic description covers multiple scenarios.
Old Jan 29, 2014 | 06:56 AM
Spotty's Avatar
Spotty
During that 5 minutes does the starter engage and crank over and just not fire.....or does the starter not even engage?
Old Jan 30, 2014 | 10:00 PM
eramone1's Avatar
eramone1
In reply to Spotty. The starter will crank but won't fire. It will just keep cranking. What's wierd is at times, but very rarely, it will start after about 5 minutes, like there was no starting problems to begin with. Would excessive heat on the starter cause it not to start? Thanks for any advice.
Old Jan 31, 2014 | 06:09 AM
Spotty's Avatar
Spotty
If the starter cranks, I would guess the issue is elsewhere. Does it have PATS? Try a second key if it does. Sounds like maybe a fuel issue. When it does that, turn the key off then turn it to the run position. Leave it there for 5 seconds and see if you hear the fuel pump energize. Also...when it does start does it run rough at first or is all smooth?
Old Jan 31, 2014 | 06:30 AM
mrpout's Avatar
mrpout
I had the same problem on my 2001. It was my fuel pump going bad.
Old Jan 31, 2014 | 11:08 AM
projectSHO89
The 1998 F150 does not have PATS.
If the engine cranks, there is nothing wrong with the starter (unless you manage to eventually burn it up).
That leaves at least one of the three mandatory elements for engine operation missing: Air, fuel, and spark.
To test for "air", crack the throttle 1/4 way. if it fires, the IAC is probably stuck shut.
To simultaneously test for fuel and spark, shoot a bit of starter fluid in the throttle body. Crank it and see if it fires.
If it fires and runs for just a few seconds on the starter fluid, your fuel supply is missing (pump, etc).
If it fails to fire, spark is missing. Check the fuses for the ignition circuit and for the PCM for beginning steps.
Because your symptoms are intermittent, the fuel pump is the strongest suspect. you can confirm this with a fuel pressure gauge.
Old Feb 1, 2014 | 06:41 AM
Spotty's Avatar
Spotty
I bought a used steering column for my 98 F-150 and it had a PATS module on it. All I wanted was the shift rods and bushings so it didn't matter. Maybe it was from another year but labeled wrong..
Will starting fluid harm the coating inside the throttle body?
Old Feb 4, 2014 | 05:26 AM
Outdoors4life's Avatar
Outdoors4life
Sounds like my truck a last year. It went on for about 6 months and I ended up changing my fuel pump after much debate. I was told it could not be that but it has not happened since. Be careful when taking off the filler tube. It is spendy to replace.
My truck would turn over but not start then start a minute later.
Tyler S
27
Jun 19, 2015 09:09 AM
FireTail-AR
Jul 14, 2007 06:34 PM
HUNTER10
Nov 25, 2006 08:30 PM
62Cole
16
Jul 2, 2006 03:19 AM
brs127s
Jan 6, 2004 09:46 PM
