Sponsored by: Auxito
98 F150 Help installing V6 4.2 Engine
Old Feb 4, 2014 | 10:02 AM
Wolvez's Avatar
Wolvez
Question 98 F150 Help installing V6 4.2 Engine
The transmission is on the vehicle supported by a pipe. Do I need to jack the transmission up while lowering the engine to the vehicle?
Old Feb 4, 2014 | 11:36 AM
Bluegrass 7's Avatar
Bluegrass 7
I can't see it but the natural requirement is to be able to mate the motor with the transmission so the bell squarely meets all the way around without forcing.
Be sure the converter does not slide forward at anytime because it is [indexed] into the transmission front pump.
Anything happens here and you force it together, damage occurs the moment you crank the motor.
Good luck.
Old Feb 4, 2014 | 11:57 AM
Wolvez's Avatar
Wolvez
Can the engine be lowered to the mounting point without mating it to the transmission?
Old Feb 4, 2014 | 12:04 PM
Bluegrass 7
If there is room and no interference , yes.
What is this all about?
Old Feb 4, 2014 | 12:25 PM
Wolvez's Avatar
Wolvez
I'm just looking for other more safer option installing the engine.
pnp522
May 29, 2014 10:51 AM
stone75
1997 - 2003 F150
Jun 1, 2009 09:45 PM
vsf100
2004 - 2008 F150
Jan 27, 2008 08:40 AM
sgtbgirl
1997 - 2003 F150
Dec 14, 2006 03:51 AM
chrisbouley
1997 - 2003 F150
May 24, 2005 04:51 PM
