Turbo IDI
Old Jan 13, 2014 | 08:47 PM
88LX5.0H's Avatar
88LX5.0H
Turbo IDI
I'm trying to help a buddy out but I'm having a hard time with it. He has a 94 IDI with the factory installed turbo set up. It has a major exhaust leak. The little tiny y pipe that goes up into the turbo is where it's leaking. There's no gasket there at all and the Ford dealership says it just slides up in there and it's supposed to seal, which I don't think that's right. There has to be some sort of gasket or something. And obviously my dealership isn't worth a damn, and none of the parts stores even understand what I'm talking about.
This is the little y pipe I'm talking about. The part that's at the top of the picture is where it goes up to the turbo, and that's where it's leaking at. Does anybody know where I can get this gasket or how I can fix this? Also, I was told this was a Banks system, is that correct?
Old Jan 14, 2014 | 08:33 AM
tjc transport's Avatar
tjc transport
i ain't rite
factory turbo is an ATS system, not banks.
you will most likely get better help down in the Pre-Power Stroke Diesel (7.3L IDI & 6.9L) forum, the guys down there eat sleep and breathe IDI diesel exhaust!.
Old Jan 14, 2014 | 09:45 AM
FORDF250HDXLT's Avatar
FORDF250HDXLT
Toms' kidding of course................we need the occasional nibble on a ball joint and drink of atf to properly sustain us.
Old Jan 14, 2014 | 10:01 AM
tjc transport
i ain't rite
mehhh. i prefer king pins. they last longer, and taste better.
Old Jan 14, 2014 | 12:06 PM
88LX5.0H's Avatar
88LX5.0H
Once I get home on my computer ill see if a mod will move this post for me. Thanks for the suggestion!
Old Jan 14, 2014 | 01:01 PM
tjc transport
i ain't rite
i will ask for you.
Old Jan 14, 2014 | 07:47 PM
LSO1123's Avatar
LSO1123
If I'm looking at it right that's the bottom part of the two piece up pipe that runs from the exhaust manifold/cross over pipe up to the hot side of the turbo. The dealership is correct, unless I'm badly mistaken there is no gasket where the two pieces of the up pipe connect. I've read a lot of threads about guys having problems getting a good seal at that connection. That's why when I installed a 093 turbo in my '93, I didn't separate that up pipe when I installed it. I don't really have any advice on how to get it to seal other than from what I've read, once it gets a good soot build up around that connection it should seal.
Old Jan 15, 2014 | 02:06 AM
hairyboxnoogle's Avatar
hairyboxnoogle
Yea its supposed to seal with soot, but like mine, its wore enough that soot wont fill it. Best advice i have, weld it, but you most likely have to pull the engine to install it.
Old Jan 15, 2014 | 08:15 PM
typefour's Avatar
typefour
There is no gasket, when its worn from rattling around it is near impossible to seal. I do have some new ones, both pieces.
Old Jan 15, 2014 | 10:11 PM
1972RedNeck's Avatar
1972RedNeck
Old Jan 17, 2014 | 04:48 PM
88LX5.0H's Avatar
88LX5.0H
I just put a rather large bead of silicone around it and let it cure for about half an hour. Problem solved (temporarily). Lol
Old Jan 17, 2014 | 07:06 PM
'94IDITurbo7.3's Avatar
'94IDITurbo7.3
i went threw a heck of a time trying to get mine to seal up good. eventually got to the point that i said screw it, and got new pipes from Russ(typefour). Really is the way to go. the new pipes fit together so nice and tight and seal up great. I now have ZERO leak at that connection.
big ole ford
Feb 12, 2015 09:08 AM
pontichev
Mar 14, 2009 05:44 PM
ncfirefighter46
26
Jan 24, 2007 09:35 PM
John7894
May 21, 2006 10:29 PM
jtharvey
17
Feb 10, 2006 01:35 AM
