well is there a gasket for the turbo mine is leaking i got the pipes off and notice the two parts look like they just go together and no seal so how is it to seal. she is leaking real bad, and are they gasket on the maifolds? where the pipe goes
No gaskets for the manifold flanges or ball sockets on turbo castings. Is that an ATS or factory Ford turbo? I've been hearing this problem more and more on here. Not sure what is the best fix.
Spray the metal gasket with copper high heat spray gasket maker. Also spray the bottom of the turbo and the top of the up pipe. Let the gasket maker dry completly before you assemble it.
Also when you have it apart, wire brush the studs and use never sieze on the threads when you assemble it so you get good clamping from the studs.
With the boost I am running I just had to do all mine last weekend.
I also found catyalytic converter gaskets I put between the ball and socket connections that ATS and Ford used on the exhaust at the manifolds. Coated them with the copper gasket maker as well to stop the high pressure leaks.
well i got the bolts out of the mainfolds by heating it up with a torch and backing them out slowly, i bought all new bolts. to go back with antiseize, i just need to try to take the other 2 bolts out where they go i to the y part, and do you know who makes the spray gasket?? ad i was planning on cleaning all the parts.
now i have the loud tick in the motor area i think this is the problem. due to it leaking very bad.
wondering if the person who installed the turbo did not replace the factory studs that hold the up pipe to the passenger manifold. The nuts on the original studs will not let the y connector come up tight to the manifold.
well i know the bolts and the studs are in bad shape and i was able to heat the manifold and remove them and new grade 5 bolts are going back with anti seize
I went out to NAPA and went thru there exhaust gaskets till I found one that the bolt holes almost lined up and the exhaust hole was the correct size. Have no idea what it fit, the description that came up on the reciept was catalytic converter flange gasket.
The bolt holes in the gasket were 1/4" to close together, but a little work on the drill press fixed that.
My ball socket was not loose, but it did leak a little at idle. At high boost I am sure it was leaking more since I had some soot stains on my nice red motor.
I also found some stains above the exhaust manifold on cylinder 7 so I did the exhaust manifold gaskets while I was in there.
Replaced all the bolts with grade 8, never siezed everything and increased the torque to 45 foot pounds in both the intake and exhaust manifolds. No more leaks when the boost goes over 20 PSI.
My real problem was the intake/valley pan gasket was letting boost into the cooling system at cylinder 5 intake port. Not enough gasket material there to stop 20+ PSI of boost. So far the copper gasket maker and the increased bolt torque is doing the job nicely though.
I guess it will take me a couple months to see if it stands up in the long run though. The stock gasket took 6 months to blow.
While I was in that far, I pulled the heads. The head gaskets were perfect with no signs of leaking or seeping, so the head studs are doing their job nicely.
I had done some testing running propane on it a couple weeks ago and thought I toasted a head gasket when the compression was showing up in the cooling system. But if I kept the boost under 12 PSI I never had boost show up in the cooling system. So I was thinking it was in the intake even before I tore it down.
I had the propane set to kick in at 8 pounds of boost, all I can say is you better hang on. Boost shoots up a couple pounds, black smoke is all gone and we are outta here. Whew boy.
I also found I had a couple bad injectors, so I called DPS this week and Ken is building me a matched set of Stage 1's. Can't wait till they get here.
