Big Decision...
Old Jan 19, 2014 | 09:31 PM
  #151
nodesy's Avatar
nodesy
Oh, one other thing. I am very diligent on maintenance - that won't be an issue. However, there might be some changes I need to make on my maintenance program. Has anything been drafted (maintenance schedules) on the forum for recommended maintenance (fluids/filters/flushes)? I guess I need to look around...
Old Jan 19, 2014 | 09:39 PM
  #152
m-chan68's Avatar
m-chan68
Originally Posted by nodesy
If I pull the 6.0 out of my truck, do you recommend any work/inspection be done to it before I put it into the Excursion? I was thinking of taking the truck down to Ford and have them check it over. However, the last time I did that (30,000 miles ago), they told me I had $4,500 worth of work to do on it. I got a second opinion, changed out the ICP sensor myself and it has been running like a champ ever since. Kind of soured me on Ford service departments to be honest...
Can you elaborate on the point highlighted in bold red?
Old Jan 19, 2014 | 09:42 PM
  #153
nodesy's Avatar
nodesy
whole fuel system, ICP sensor, HPOP. All tested fine when I got a second opinion, besides the ICP sensor, which I replaced. It sounded like they were just assuming it was going to fail since it had 100,000 miles on it. I wish I could give better detail, but that was 4 years ago. The truck runs just as good now and cold starts better up here with the change to 5w-40. Comments?
Old Jan 19, 2014 | 09:52 PM
  #154
m-chan68's Avatar
m-chan68
2003 specific model year engines do tend to suffer from weak high pressure oil pumps. And when the mileage gets high, you would be well advised to replace it. Obviously with the engine physically out of the vehicle, this job is much easier than laying with your stomach on top of an engine inside the engine compartment lifting heavy parts out to access and replace it. And yes, ICP sensors should definitely be considered a regularly replaced item, due to where they are located under the turbo at the back of the engine, hence why it changed location mid-2004. On a bright note, your 2003 engines have the beefier EGR coolers that will likely never fail, unlike to mid-2004 and later versions. Other than that, I can't really think of anything else to address on that engine if everything else seems to function as needed.
Old Jan 19, 2014 | 09:56 PM
  #155
Edogsf350's Avatar
Edogsf350
at what milage would you recommend replacing the HPOP as a maintenance/precaution repair?
  #156
nodesy's Avatar
nodesy
Thanks for the tips. Now that you say that, I think I will go ahead and replace the HPOP. I have also heard that it is a good idea to replace the oil cooler at this juncture. I had also planned on doing the EGR delete, but I guess I can get a better look while the engine is out before I make that decision. While the engine is out (if I pull it), do you recommend anything else?
Old Jan 20, 2014 | 03:36 PM
  #157
DawnPatrol's Avatar
DawnPatrol
Originally Posted by run6.0run
I actually pulled my engine THREE TIMES!!!!! The first was at 582k mi due to the lifter life (10 were bad). I had to rebuild it again after 130k due to my STUUUUUPIDazz decision to have my cam reworked by a reputable company. I also decided to balance my crankshaft on the second rebuild,,, a local shop SCREWED me and it vibrated like crazy,, so I pulled it again and had the crank rebalanced. I can pull the engine in a couple hours,, so it's not as big if a deal to me as it would be for others. But I also did all this experimenting on MY OWN engine. No way in heck would I make any of those decisions if it was a paying job. But I wanted real world experience personally before I suggest anything to a customer.
Wow! If you were near San Diego I'd pay you to pull mine... small problem... just an annoying bed plate seep
other than that runs perfecto
Old Jan 20, 2014 | 08:25 PM
  #158
Mr.Nobody's Avatar
Mr.Nobody
I understand that we are just speculating and talking it out here, but are we getting the cart in front of the horse? This conversation would be more productive after you pull the motor on the EX.
Seems like all the options you want to consider, have you pulling the motor. I'm a bit neive as to what is actually wrong with the engine, all I saw was a busted up injector, so I don't know what that translates into on the inside. Shouldn't you at least pull the head off and look at the inside before you start making too many plans?
Is the truck at the dealer still? My uneducated opinion on the mater would be: sell one truck, use money to fix the other. Is one of these three trucks a spare? Sell the F-350 (if your just gonna pull the motor anyway), or sell the dodge. This would help offset the cost of fixing the Excursion correctly, and not hashing something together.
OR, sell the Ex, and one truck, and find an Ex that runs. Perhaps I'm miss understanding your situation though?
Old Jan 20, 2014 | 09:16 PM
  #159
m-chan68's Avatar
m-chan68
THAT, is definitely some very sound, good advice there. I would say, sell the Dodge and the Excursion, and continue your search for one that you don't need to go inside the engine.
Old Jan 21, 2014 | 06:30 PM
  #160
nodesy's Avatar
nodesy
You guys are going to be totally upset with me. I broke down, drove to Salt Lake City last night and bought ANOTHER Excursion. This time a 2000 7.3 liter with 230,000 miles, $7,900. The plan is now to sell the 2003 6.0 1 ton flatbed that I have and my Volkswagen to recover some costs. I still plan to get the 6.0 Excursion on the road as well. This way, I will have a 5.9 Cummins, 6.0, and 7.3 parked outside. This was simply to buy me some time - we needed a reliable backup vehicle as well anyway. I still plan on digging into the 6.0 before long. That is going to be our everyday driver. Hopefully you guys are still willing to help.
By the way, the 7.3 - runs like a champ. 25 degree cold start produced almost no smoke whatsoever. The thing is pristine. It was a family hauler that never saw a trailer in its life. One owner. Couldn't pass it up. We will be taking it across country and back in March. My wife is very happy.
Old Jan 21, 2014 | 07:31 PM
  #161
Unrealo4's Avatar
Unrealo4
Lol so your close to slc? What are you asking for broke down 6.0 ex?
...edit sorry I thought you were selling the questionable Ex.
Old Jan 21, 2014 | 07:38 PM
  #162
texastech_diesel's Avatar
texastech_diesel
Token Redneck
The 7.3 will run great.... right up until you have to jam a pair of quarters into the injector harnesses to keep it spinning
We'll be here when you need us
Old Jan 21, 2014 | 07:50 PM
  #163
Snowseeker's Avatar
Snowseeker
You'll love that 7.3 Nodesy! Welcome to the good side.
Old Jan 21, 2014 | 07:57 PM
  #164
Mr.Nobody's Avatar
Mr.Nobody
NOOOOOO, you where so close to the dark side!
Old Jan 21, 2014 | 08:03 PM
  #165
Per4mance's Avatar
Per4mance
Ya know.......there goes a good thread....LOL
