Strange coolant leak
Old Jan 2, 2014 | 05:24 PM
Farmerrye's Avatar
Farmerrye
Question Strange coolant leak
I have a stock 04 and this morning I noticed coolant dripping fairly consistently from the passenger side of the engine near the firewall. I have some pictures I will attach. It is hard to tell where it originates.
I am noticing a lost of coolant. Should I pressure test the system?
The ect and eot spreads are normal.
Any suggestions would be much appreciated.
Old Jan 2, 2014 | 05:27 PM
Farmerrye's Avatar
Farmerrye
I can see the coolant run down the exhaust manifold, the highest I can see coolant appears to be near the top of the block.
Old Jan 2, 2014 | 05:45 PM
mustang_309's Avatar
mustang_309
Its likely the blue/orange hose between the EGR cooler and the oil cooler housing, look on top of the engine on passenger side between the alternator and the turbo.
Old Jan 2, 2014 | 05:46 PM
9228.bobcat's Avatar
9228.bobcat
X2 that would be my guess as well.
Old Jan 2, 2014 | 06:35 PM
69cj's Avatar
69cj
Could also be the heater control valve or hose. Wouldn't be the first one.
Old Jan 2, 2014 | 06:38 PM
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
You'll be looking for this culrpit...
Either it's original orange or blue.
Josh
Old Jan 2, 2014 | 06:40 PM
Bullitt390's Avatar
Bullitt390
That's true, this little gizmo can get fubar'd as well.
Josh
Old Jan 3, 2014 | 11:58 AM
Farmerrye's Avatar
Farmerrye
Thanks guys, I will check it right now. If it is leaking from the egr /oil cooler hose then I should replace it including the clamps? Will I lose a bunch of coolant? Or should I drain the whole system first?
Thanks for the advice and the pictures.
Ryan
Old Jan 3, 2014 | 12:20 PM
Bullitt390's Avatar
Bullitt390
The hose twists off... You'll remove the adapter cover and replace it that way.
https://www.ford-trucks.com/forums/1...e-install.html
There is a better thread with pics on this particular repair but I cannot find it at the moment.
Josh
Old Jan 3, 2014 | 05:20 PM
Farmerrye's Avatar
Farmerrye
Sorry but I am new to this engine so correct me if I'm wrong,
Remove the cover on the oil filter housing and then pry the hose off. Replace it and close it up? I have an orange hose in there, what size is it? Any other tricks and tips to help me replace it, it's tight as hell in there......
Old Jan 3, 2014 | 05:37 PM
Bullitt390's Avatar
Bullitt390
Drain about 2 gallons of coolant.
You twist the orange hose and line up the double dash lines and push it towards the EGR cooler.
Remove the cover with T30 torx. Slide the hose off and install the new blue hose.
Install cover.
Slide the hose forward and twist to lock it.
Add coolant.
Josh
Old Jan 6, 2014 | 10:11 PM
9228.bobcat
Bump bump bump
VA13FX4
Jun 14, 2019 08:30 AM
martial315
Apr 25, 2019 10:10 AM
COVeteran
Nov 20, 2017 12:59 PM
jpcjguy
Aug 19, 2016 10:04 AM
aarmao
2009 - 2014 F150
20
Mar 13, 2013 08:48 AM
