Cold start issue....do I still have a GPR problem?
Old Nov 21, 2013 | 10:16 AM
schlepprock250's Avatar
schlepprock250
^^^ This..when I discovered that Lucas was my issue I got it out. Its easy for us to spend your money but that's what I did. I went with Rotella T6 5 w40. Its a full synthetic and my truck runs much better on it.
Old Nov 21, 2013 | 10:36 AM
Tact's Avatar
Tact
I think I'm going to change it out today. Do I like spending another $100 on an oil change when I just finished doing one......No, but I'm not liking what "could" happen to my engine.
If I go with the synthetic oil, I guess my oil change interval could be extended past the 5K mile interval I have always followed. I know that there are many thoughts on this topic, but is the general consensus 7500 miles to justify the extra cost?
Old Nov 21, 2013 | 10:56 AM
schlepprock250
I still only go 5000 miles. Having a quieter/smoother running engine justifies the additional cost for me.Jmho..
Old Nov 21, 2013 | 10:57 AM
grec-o-face's Avatar
grec-o-face
Same here.
Old Nov 21, 2013 | 12:54 PM
Tact's Avatar
Tact
Well....I just finished changing the oil to T6 and changed the filter. We'll see if it improves the cold start issue. I feel better already just to get the Lucas out of my system.
Old Nov 22, 2013 | 12:25 PM
Tact's Avatar
Tact
UPDATE.....Although it wasn't that cold this morning, 57 degrees, after starting she fired right up and there was no stumbling. The oil change seems to have fixed my starting issues.
Now the question, was it the synthetic oil that cured the problem or was it merely changing the oil and getting the Lucas out of my system. Only thing I am sure of is that I'm not going to change the oil again to find out.
Sunday morning the lows are going to be in the mid 20's. I'll have a better idea then. As for now, I'm happy.
Thanks for the help once again.
Old Nov 22, 2013 | 08:10 PM
Tugly's Avatar
Tugly
I'm reasonably sure they both played a part. Getting the Lucas out alone may have helped with the romps, but the synthetic will make sure everything works all the way down the thermometer. I've always run synthetic and I've started in sub-zero weather (unplugged) with zero issues. I experienced the romps just one time when I accidentally short-cycled the glow plugs - it was a newbie mistake.
Old Nov 22, 2013 | 08:29 PM
puller45's Avatar
puller45
I use T6 year round and change at 10,000 miles. Blackstone reports say I could go 12,000 except when I've been towing my 5th wheel for 6 or 7 thousand of those miles. They recommend 8500 then. I routinely go out at 20,000 lbs truck and trailer.
Old Nov 22, 2013 | 08:34 PM
Tact's Avatar
Tact
If I keep using synthetic I might push 7500 mile oil change intervals, beyond that I have a pucker factor I would have to contend with.
Old Nov 22, 2013 | 08:49 PM
tdpower's Avatar
tdpower
You didn't get it all out. There is about 2-3 quarts in the hpop resevoir and the rails that don't get removed during a normal drain. Probably won't matter with the synthetic but I would change it out in 4-5k.
Old Nov 22, 2013 | 08:53 PM
Tact's Avatar
Tact
Yeah....but it still feels better.
Old Nov 22, 2013 | 09:01 PM
tdpower's Avatar
tdpower
Well as long as you are good with it that is the important thing. You may eventually get it out by the process of dilution..lol...jk
Old Nov 22, 2013 | 09:56 PM
  #28
BWST's Avatar
BWST
Got Data?
Agree with that. 7500 is what I do with T6 currently - actually looking forward to getting T6 back in it. Had dino oil from the last injector cup job.
Some frost showing up in Seattle last few mornings. Another 0.001" of accumulation and we shut down around here...
mstiles19
Feb 11, 2013 02:39 PM
Yahiko
Jan 13, 2013 04:32 PM
kingair41
May 21, 2012 08:38 PM
URDADDY
Jan 27, 2012 09:04 PM
silly34
Dec 12, 2009 10:34 PM
