I just bought a 2006 6.0L crew dually a few weeks ago.
When I start it up cold it'll crank fine for about 4-5 seconds then it will start. As soon as it starts it will stumble at trying to stay running then die.
When I crank it over the second time it will start and stay running with a lot of smoke coming out of the exhaust pipe. It clears up after a few seconds.
I'm a novice when it comes to all those sensors and their abbreviations and functions but I'm learning as I go.
I usually have to leave it running for 10 minutes or so to warm it up before I can drive off with it.
When I do I'm leaving a nice smoke trail behind me. So much so sometimes I loose site of traffic behind me.
The tranny temp on the cluster indicates operating temp range.
The Coolant gauge shows about 1/4 of the way to operating temp. So I would think it is warm enough to drive off.
If I try to accelerate with the smoke coming out the tail pipe the truck will buck and act like one or more of the cylinders are cutting in and out.
This goes on for about a 1/4 mile or so then it suddenly stops and runs great after that.
It only does it on cold start ups in the morning. Warm starts are fine. No smoke or hesitating.
I was able to borow a friends scanner to see what the air temp sensors were reading when cold. They were reading ambient temp in the morning before the cold start up.
The Best thing you could do at this point is invest in a ScanGaugeII
Handy Gadget for shure it will show you just about every sensor on the 6.0L engine and even some trans stuff. You can program 25 gauges you want specificaly in addition to what already there
theres 40-50 gauges to pick from that are specific to the 6.0L Ford
You have at least 1 bad injector. With it over fueling so much. I would focus on replacement asap. I've read story's of this kind of thing melting pistons and or destroying cylinders.
As Unreal said injector is a definant possibility, but I would still check FICM. Cold truck is better. Here's link to the instructions: https://www.ford-trucks.com/forums/s...d.php?t=303583 posts 5-9 are all about the FICM, #5 is the test. Just need a torx driver, wrench, volt meter, and a helper to turn the key. Takes 30min or less.
