P0405/ p0404
Old Feb 4, 2014 | 11:12 AM
  #61
npccpartsman's Avatar
npccpartsman
Originally Posted by Mr.Nobody
So, I was looking through the dashboss log from yesterday's test drive, and I noticed that the EBP sensor shows 0 at KOEO. Ordered up a new one so we shall see if that takes care of some of my driving issues. It has showed that for quite some time, but I guess I never really noticed it. Just sitting there right in front of my face.
I have a 2005 MY Excursion, but it has the 2004 sticker on the motor, and the EBP sensor is on the T-stat braket. Do I order parts for a 2005 or for a 2004?
IIRC yours isn't the only one I've seen like that. You might shoot Bullit390 a PM and ask him if that's normal for the dashboss. What does it show running? Does it respond at all and is it showing a code? AFA the part # goes it should be an 04 (if there's even a difference) but take the VIN for confirmation.
Old Feb 4, 2014 | 11:29 AM
  #62
Mr.Nobody's Avatar
Mr.Nobody
It does respond to throttle and such, but never even reaches Baro. Stumbled across an old thread that a couple of you 6.0 wizards had posted on, and that is what brought it to my attention. Funny thing about it is that the information has been in front of me the who,e time, but I just didn't know how to translate it.
Old Feb 4, 2014 | 12:52 PM
  #63
Bullitt390's Avatar
Bullitt390
Certified Thread Hijacker
Yeah that's strange.
Good time to clean out the tube also with the new sensor.
Josh
Old Feb 4, 2014 | 06:17 PM
  #64
cheezit's Avatar
cheezit
Suspect possible bad connector as well.
Old Feb 4, 2014 | 06:31 PM
  #65
Mr.Nobody's Avatar
Mr.Nobody
I messed with it, got the tube cleaned out with weed eater line and such. The plug "looks" good, but I did not check it with my VOM. The EBP readings are exactly what they have always been since I got the truck, starting to figure out all the little reasons why the PO traded it in.
Old Feb 4, 2014 | 09:18 PM
  #66
daddykitty's Avatar
daddykitty
my bad oops
Old Feb 21, 2014 | 01:06 PM
  #67
Mr.Nobody's Avatar
Mr.Nobody
Update on this one. New EBP sensor from RiffRaff, numbers are better. Turbo makes a light whistling noise while idling that I'd never heard before. So that's progress, but the p0404 has come back. Just randomly, and not every time I drive the truck. Ordered up some new hot side CAC boots, because the ones on there are weeping oil pretty badly. Probably not related, but it is maintenance that needs to be done.
Old Feb 21, 2014 | 06:21 PM
  #68
Snuggyworm's Avatar
Snuggyworm
Good job! I'm glad to hear tat ur making progress!
Dom
Sent from my iPhone using IB AutoGroup
Fulthrotl
May 5, 2013 01:15 AM
ravens fan
Mar 21, 2013 08:26 AM
Fluid Power
May 30, 2007 12:32 AM
e-manfive
Nov 27, 2004 07:31 AM
StevePitts
Mar 22, 2004 04:02 PM
